I am writing a Arduino program to get data from Schneider EM6400NG by using Arduino MEGA 2560. Arduino is Master, device is slave.
Aim :- To read holding register of EM6400NG energy meter, and Collect energy parameter from device
here in used : ModbusMaster library
EM6400NG register address Link :-
Problem:- When I run code in IDE Arduino, and print Result Value monitor display error 226 - in below code i have removed all seril print
Then I remove Arduino and just use RS485.
- When I use Modscan software. I can completely read data from device
Is there something wrong with the request signal? Am I making any mistakes in the circuit or the code?
i checked my rs485 ti ttl module using arduino to pc data communication its work fine, whats wrong in program or anything other
please help me for this, all the details : circuit diagram, Arduino code and received output attached, PFA
Code for read Holding register
// ****** DEFINES ******
#define MAX485_DE 3
#define MAX485_RE_NEG 2
// ****** INCLUDES ******
#include <ModbusMaster.h>
// ****** GLOBALS ******
ModbusMaster node; // instantiate ModbusMaster object
float reg1; // will store the float value found at 3910/3911
float reg2; // will store the float value found at 3914/3915
int low_word; // this will hold the low 16-bit resgter value after a read
int high_word; // this will hold the high 16-bit resgter value after a read
// converting to floating point - union structure
union u_tag {
int bdata[2];
float flotvalue;
} uniflot;
// ****** Transmission Functions ******
void preTransmission()
digitalWrite(MAX485_RE_NEG, 1);
digitalWrite(MAX485_DE, 1);
Serial.println("preTransmission");
void postTransmission()
digitalWrite(MAX485_RE_NEG, 0);
digitalWrite(MAX485_DE, 0);
Serial.println("postTransmission");
// ****** STANDARD ARDUINO SETUP FUNCTION ******
// make pins 2 and 3 output pins for Max485 flow control
pinMode(MAX485_RE_NEG, OUTPUT);
pinMode(MAX485_DE, OUTPUT);
// Init in receive mode
Serial.begin(9600); // TX0/RX0 serial monitor
Serial1.begin(9600,SERIAL_8N1); // TX1/RX1 Modbus comms
// Modbus slave ID = 1
node.begin(1, Serial1);
// Callbacks allow us to configure the RS485 transceiver correctly
node.preTransmission(preTransmission);
node.postTransmission(postTransmission);
// ****** STANDARD ARDUINO LOOP FUNCTION ******
uint8_t result;
// Read Line to Neutral Voltage
result = node.readHoldingRegisters(0x3028, 2);
//result = node.readHoldingRegisters(1, 2);
if (result == node.ku8MBSuccess)
high_word = node.getResponseBuffer(0x00);
low_word = node.getResponseBuffer(0x01);
uniflot.bdata[1] = low_word; // Modbus data 8-bit low word
uniflot.bdata[0] = high_word; // Modbus data 8-bit high word
reg1 = uniflot.flotvalue;
Serial.print("Line to Neutral Voltage: ");
Serial.println(reg1);
// node.clearResponseBuffer();
delay(500); // small delay between reads
//Read Frequency
result = node.readHoldingRegisters(3110, 2);
reg2 = uniflot.flotvalue;
Serial.print("Frequency: ");
Serial.println(reg2);
delay(1000); // repeat reading every 2 seconds
EM6400.ino (2.78 KB)
