Error in sample code for a DC Motor
I have a project using this motor spinning to spin a rod. I’m just trying to get the motor to work. I’m using an Arduino UNO Wi-Fi Rev 2. The website link shows a picture of how I connected my wires to the Arduino. I connected wires 2 and 5 to a 12V DC Battery Power Supply. I connected wire 1 in pin 10, wire 3 in pin 11 and wire 4 in pin 9 on the Digital PWM~ side. I’m not really sure how to fix this error because I don’t really know this coding language well.
My error message:
/Users/margotclyburn/Documents/Arduino/motorex1sketch/motorex1sketch.ino: In function ‘void loop()’:
motorex1sketch:16:26: error: cannot convert ‘bool’ to ‘PinStatus’ for argument ‘2’ to ‘void digitalWrite(pin_size_t, PinStatus)’
digitalWrite(10, flag);
exit status 1
Here is the sample code I input:
int i = 0;
unsigned long time = 0;
bool flag = HIGH;
  pinMode(10, OUTPUT); //PWM PIN 10  with PWM wire
  pinMode(11, OUTPUT);//direction control PIN 11 with direction wire
  if (millis() - time > 5000)  {
    flag = !flag;
    time = millis();
  if (Serial.available())  {
    analogWrite(11, Serial.parseInt());  //input speed (must be int)
    delay(200);
  for(int j = 0;j<8;j++)  {
    i += pulseIn(9, HIGH, 500000); //SIGNAL OUTPUT PIN 9 with  white line,cycle = 2*i,1s = 1000000us,Signal cycle pulse number:27*2
  i = i >> 3;
  Serial.print(111111 / i); //speed   r/min  (60*1000000/(45*6*2*i))
  Serial.println("  r/min");
  i = 0;
website I got the code from: FIT0441_Brushless_DC_Motor_with_Encoder_12V_159RPM-DFRobot
Motor: Brushless DC Motor with Encoder 12V 159RPM
Battery Power Supply: 12V DC Battery Power Supply - 8-Cell AA Battery Holder | Super Bright LEDs
you are declaring 'flag' as a bool but the digitalWrite() function doesn't want a bool for the second argument. Change your flag to an int or byte type
You are experiencing the problem described here
But the API that comes with Arduino IDE 1.8.9 is different. It declares digitalWrite as
void digitalWrite(uint8_t, uint8_t);
It does not have this problem.
What exactly are you using to compile your code? Arduino IDE?
Montmorency:
By "the API that comes with Arduino IDE 1.8.9", you are referring to the bundled Arduino AVR Boards core. Uno WiFi Rev2 does not use Arduino AVR Boards. It uses Arduino megaAVR Boards, which is the first core to use ArduinoCore-API:
Thus is serves as our preview of what could happen if ArduinoCore-API was integrated into the more commonly used cores with the current PinStatus enum system in place. However, the Arduino developers are now aware of the issue and I think they understand it needs to be resolved before that happens.
