Error in Serial.read()
I have a UNO board. At present, I’m learning to use Bluetooth module with Arduino. To begin with, I created a simple sketch to turn ON and OFF led by sending commands from my android phone to Arduino through Bluetooth module HC05.
int LED= 13;
int input;
  pinMode(LED, OUTPUT);
  Serial.println(">> START<<");
  if(Serial.available()>0)
    Serial.print("available");
    input= Serial.read();
    if(input=='1')
      Serial.println("ON");
      digitalWrite(LED, HIGH);
    else if(input=='0')
      Serial.println("OFF");
      digitalWrite(LED, LOW);
      Serial.println("NO INPUT");
      Serial.println(input);
connections are:
VCC to 5V
GND to GND
TX to RX [0th pin]
RX to TX [1st pin]
The problem is when I press value ‘1’ or ‘0’ from android phone, I get incorrect values in the serial monitor.
I have attached the photocopy of serial monitor output.
So you are talking to the bluetooth module and the Serial monitor with the same port? Connecting 2 devices to the same port will not work. Consider using a software serial port for the bluetooth (several libraries available) and hardware serial (pins 0 and 1) for messages to serial monitor.
softwareSerial
groundfungus:
softwareSerial
Yes. and what that delay(1000) is doing there ??
-Malhar
