Error in shifting data bytes
Hello everyone,
I need little assistance in shifting four bytes in a variable. I am reading four bytes from device that is connected to Arduino. The sequence of four bytes is BC 0D 05 15. I am putting them in a variable so that it becomes 0515BC0D. I am doing it as shown in the sketch below. I have in total 31 bytes where byte 05 is at 25, 15 at 26, BC at 23, and 0D at 24.
  unsigned long int combined = 0;
  long x0 = incomingBytes[25] << 24;
  long x1 = incomingBytes[26] << 16;
  long x2 = incomingBytes[23] << 8;
  long x3 = incomingBytes[24];
  combined = x0 | x1 | x2 | x3;
  Serial.println(x0);
  Serial.println(x1);
  Serial.println(x2);
  Serial.println(x3);
  Serial.println(combined);
The above sketch works fine on MKR 1400 board and I get the value in variable combined = 0515BC0D, but on Arduino UNO board when I print the values this is what I get:
x0 = 0
x1 = 0
x2 = FFFFBC00
x3 = 0D
combined = FFFFBC0D
May I know why do I get the above values and not the values as on MKR board? Thank you
A quick guess is that you need to cast incomingBytes to a long before doing the shift for each of x0, x1 x2 & x3. But that's just a guess since you've not posted all your code and we can't see your declaration of incomingBytes.
MKR 1400 is 32 bits, Uno is 8 bits. Variables are treated differently.
guix:
Oh okay. Yeah, my data is 32 bits and that's why UNO isn't able to handle it. Thanks guix for the input.
You can do it something like this which works also for an 8 bit MCU
  Serial.begin(115200) ;
  uint32_t combined = 0 ;
  combined = 0x05 ;
  combined = (combined << 8) | 0x15 ;
  combined = (combined << 8) | 0x26 ;
  combined = (combined << 8) | 0x0D ;
  Serial.println(combined,HEX);
#include <SoftwareSerial.h>
SoftwareSerial mySerial (8, 9);
byte incomingBytes [31];                                                           // array for 31 bytes incoming serial data
byte message [] = {0xAA, 0x03, 0x00, 0x24, 0x00, 0x0D, 0xDD, 0xDF};                // message to read 13 registers
  Serial.begin(115200);                                                            // opens serial port, sets data rate to 115200 bps
  mySerial.begin(115200);                                                          // opens serial port, sets data rate to 115200 bps
void loop () {
requestMessage();                                                               // request message function call
receivedBytes();        // received bytes function call
batterySOC();
void requestMessage() {
  mySerial.write(message, sizeof(message));                                          // send request message to wake BMS up if in deep sleep mode
  while (mySerial.read() >= 0) {                                                     // clear the buffer
void receivedBytes() {
  if (mySerial.available())
    mySerial.readBytes(incomingBytes, 31);
void batterySOC() {
  unsigned long int combined = 0;                                                      // clear it out
  unsigned long int x0 = incomingBytes[25] << 24;
  unsigned long int x1 = incomingBytes[26] << 16;
  unsigned long int x2 = incomingBytes[23] << 8;
  unsigned long int x3 = incomingBytes[24];
  combined = x0 | x1 | x2 | x3;                                                    // combining required 4 data bytes of received 8 bytes
  Serial.println(x0, HEX);
  Serial.println(x1, HEX);
  Serial.println(x2, HEX);
  Serial.println(x3, HEX);
  Serial.print("Data value in HEX = ");
  Serial.println(combined, HEX);                                                // print the 4 combined HEX bytes in HEX
  Serial.println("");
  Serial.print("Data value in DEC = ");
  Serial.println(combined, DEC);                                                // print them in decimal
  Serial.println("");
  Serial.print("State of Charge: ");
  battery_SOC = (float)combined / 1000000.0;                                       // dividing the dec values by 1000000 to get the values of SOC in BMS register
  Serial.print(battery_SOC);                                                       // print the SOC value
  Serial.println(" %");
  Serial.println("");
@markd833 that’s the sketch. That works fine on MKR board but not UNO. But I think what guix commented is the reason.
It will work if you follow given advices. I prefer how 6v6gt did it, but mark’s advice will work as well
long x0 = ((long)incomingBytes[25]) << 24;
I checked that and it worked. Thank you very much everyone for the help.
