Error in sketch- need help
Hi
Im getting the following error for the code below, ive trid but couldnt find the error, can someone help me with the correction of code?:
Error=>>
sketch_may17b_boost_only_pid.ino:162:1: error: ‘v1’ does not name a type
sketch_may17b_boost_only_pid.ino:163:1: error: ‘voltage’ does not name a type
sketch_may17b_boost_only_pid.ino:164:1: error: expected unqualified-id before ‘if’
Error compiling.
Code=>>
#include <PID_AutoTune_v0.h>
#include <PID_v1.h>
#include <math.h>
const byte pwPin1 = 5;
const byte pwPin2 = 6;
float analogPin2 = 3;
float analogPin1 = 1;
double pidPin = 0;
float v1 = 0.0;
float boostDuty = 0.0;
float buckDuty = 0.0;
float voltage;
byte ATuneModeRemember = 2;
double kp1 = 2, ki1 = 0.5, kd1 = 2;
double kpmodel = 1.5, taup = 100, theta[50];
double outputStart = 5;
double aTuneStep = 50, aTuneNoise = 1, aTuneStartValue = 100;
unsigned int aTuneLookBack = 20;
boolean tuning = false;
unsigned long  modelTime, serialTime;
double Input1 = 80.0;
double Output1 = 150.0;
double Setpoint1 = 777.0;
PID myPID1(&Input1, &Output1, &Setpoint1, kp1, ki1, kd1, DIRECT);        //PID
PID_ATune aTune(&Input1, &Output1);
//set to false to connect to the real world
boolean useSimulation = false;
  TCCR0B = TCCR0B & B11111000 | B00000001;
  pinMode(pwPin1, OUTPUT);
  pinMode(pwPin2, OUTPUT);
  if (useSimulation)
    for (byte i = 0; i < 50; i++)
      theta[i] = outputStart;
    modelTime = 0;
  myPID1.SetMode(AUTOMATIC);                                // TURN ON PID1
  if (tuning)
    tuning = false;
    changeAutoTune();
    tuning = true;
  serialTime = 0;
  float v1 = analogRead(analogPin2);
  float voltage = v1 * (5.0 / 1023);
  if (voltage >= 1.5 && voltage <= 2.5)
    analogWrite( 6, (0));
    analogWrite( 10, (0));
    analogWrite( 11, (90));
    delay(10);
    while (voltage >= 1.5 && voltage <= 2.5) {
      boostDuty = 1 - (voltage / 3.8);//calculate boost  duty ratio
      unsigned long now = millis();
      if (!useSimulation)
      { //pull the input in from the real world
        Input1 = analogRead(pidPin) * (5.0 / 1023);
      if (tuning)
        byte val = (aTune.Runtime());
        if (val != 0)
          tuning = false;
        if (!tuning)
        { //we're done, set the tuning parameters
          kp1 = aTune.GetKp();
          ki1 = aTune.GetKi();
          kd1 = aTune.GetKd();
          myPID1.SetTunings(kp1, ki1, kd1);
          AutoTuneHelper(false);
      else myPID1.Compute();
      if (useSimulation)
        theta[30] = Output1;
        if (now >= modelTime)
          modelTime += 100;
          DoModel();
        analogWrite(5, boostDuty * Output1);
        Serial.println(Output1);
        Serial.println(5);
      //analogWrite( 5, (boostDuty * Output1));
      //v1 = analogRead(analogPin2);
      //vroltage = v1 * (5.0 / 1023);
      if (voltage < 1.5)
  if (voltage < 1.49 && voltage >= 0)
    analogWrite( 5 , (0));
    analogWrite( 11, (0));
    analogWrite( 10, (90));
    delay(10);
    while (voltage < 2.5) {
      buckDuty = 1.0 / 5.0;
      analogWrite( 6, (buckDuty * 255));
      if (voltage == 2.5)
if (voltage < 0 || voltage > 2.5)
{ analogWrite( 5 , (0));
  analogWrite( 6 , (0));
void changeAutoTune()
  if (!tuning)
    //Set the output to the desired starting frequency.
    Output1 = aTuneStartValue;
    aTune.SetNoiseBand(aTuneNoise);
    aTune.SetOutputStep(aTuneStep);
    aTune.SetLookbackSec((int)aTuneLookBack);
    AutoTuneHelper(true);
    tuning = true;
  { //cancel autotune
    aTune.Cancel();
    tuning = false;
void AutoTuneHelper(boolean start)
  if (start)
    ATuneModeRemember = myPID1.GetMode();
    myPID1.SetMode(ATuneModeRemember);
void SerialSend()
  Serial.print("setpoint: "); Serial.print(Setpoint1); Serial.print(" ");
  Serial.print("input: "); Serial.print(Input1); Serial.print(" ");
  Serial.print("output: "); Serial.print(Output1); Serial.print(" ");
  if (tuning) {
    Serial.println("tuning mode");
    Serial.print("kp: "); Serial.print(myPID1.GetKp()); Serial.print(" ");
    Serial.print("ki: "); Serial.print(myPID1.GetKi()); Serial.print(" ");
    Serial.print("kd: "); Serial.print(myPID1.GetKd()); Serial.println();
void SerialReceive()
  if (Serial.available())
    char b = Serial.read();
    Serial.flush();
    if ((b == '1' && !tuning) || (b != '1' && tuning))changeAutoTune();
void DoModel()
  //cycle the dead time
  for (byte i = 0; i < 49; i++)
    theta[i] = theta[i + 1];
  //compute the input
  Input1 = (kpmodel / taup) * (theta[0] - outputStart) + Input1 * (1 - 1 / taup) + ((float)random(-10, 10)) / 100;
Regards
Emmanuel Babu
Without investigating this specific error, do you realise that the declartion of v1 (and voltage) inside your loop() function create a second variable that hide the declarations outside the loop?
As to the error - you appear to have one too many closing braces before the line
and so the compiler thinks that you are trying to declare a variable with a type of 'v1'.
Maybe you're planning at some point reading from analogue pin number 2.75?
Thank you for your time...ive got the errors corrected
Emmanuel
AWOL: float analogPin2 = 3;
Oh, couldn't that cause a really strange error if the 3 suddenly turned into a 2 because of the imprecision of floating point numbers and the fact that they get truncated when they get converted to integers?
