Greetings.
I use the Arduino SAM Boards 1.6.12 library.
After downloading the program, I get the error:
"duty <=pPwm->PWM_CH_NUM[ul_channel].PWM_CPRD"failed: file "../source/pwm c.c", line 272, function: PWMC_SetDutyCycle.
The management program looks like this:
#include <DueTimer.h>
#define PID_INTEGER
// #define PID_INTEGRAL_WINDOW 50
// #define PID_OPTIMIZED_I
#include <GyverPID.h>
double Kp_L = 0.0;
double Ki_L = 0.3;
double Kd_L = 0.0;
double Kp_R = 0.0;
double Ki_R = 0.3;
double Kd_R = 0.0;
int16_t SET_L = 511;
int16_t SET_R = 511;
#define PWM_R 8
#define DIR_R 10
#define A_R A2
#define PWM_L 9
#define DIR_L 11
#define A_L A3
uint32_t timing = 0;
uint32_t timing_dt = 0;
uint32_t dt_delay = 100;
uint32_t print_delay = 1000;
uint32_t slow = 0;
int16_t cur_pos_L;
int16_t cur_pos_R;
int16_t RC_L;
int16_t RC_R;
int16_t toLow_pos = 9;
int16_t toHigh_pos = 1023 - toLow_pos;
int16_t STOP_Low_pos = 5;
int16_t STOP_High_pos = 1023 - STOP_Low_pos;
bool trig = false;
bool dirL;
bool dirR;
int32_t timing_dirL = 0;
int32_t timing_dirR = 0;
GyverPID regulator_L(Kp_L, Ki_L, Kd_L, dt_delay);
GyverPID regulator_R(Kp_R, Ki_R, Kd_R, dt_delay);
pinMode(DIR_R, OUTPUT);
digitalWrite(DIR_R, LOW);
pinMode(DIR_L, OUTPUT);
digitalWrite(DIR_L, LOW);
pinMode(PWM_R, OUTPUT);
pinMode(PWM_L, OUTPUT);
analogReadResolution(10);
analogWriteResolution(8);
regulator_L.setLimits(-255, 255);
regulator_R.setLimits(-255, 255);
regulator_L.setpoint = SET_L;
regulator_R.setpoint = SET_R;
if (millis() - timing_dt >= dt_delay){
cur_pos_L = analogRead(A_L);
cur_pos_R = analogRead(A_R);
if (SET_L - cur_pos_L < 0) {
digitalWrite(DIR_L, HIGH);
dirL = HIGH;
else {
dirL = LOW;
if (SET_R - cur_pos_R < 0) {
digitalWrite(DIR_R, HIGH);
dirR = HIGH;
else {
dirR = LOW;
if (cur_pos_L > STOP_Low_pos && cur_pos_L < STOP_High_pos) {
regulator_L.input = cur_pos_L;
analogWrite(PWM_L, abs(regulator_L.getResult()));
else {
analogWrite(PWM_L, 0);
if (cur_pos_R > STOP_Low_pos && cur_pos_R < STOP_High_pos) {
regulator_R.input = cur_pos_R;
analogWrite(PWM_R, abs(regulator_R.getResult()));
else {
analogWrite(PWM_R, 0);
timing_dt = millis();
Can you tell me what this error is related to and how to fix it?
