I have trouble, I installed time library but still getHours was not decleard.
#include <UTFT.h>
#include <URTouch.h>
// Define the pins for your touch screen
#define TFT_RST A4
#define TFT_RS A3
#define TFT_CS A2
#define TFT_WR A1
#define TFT_RD A0
#define TOUCH_XP A2
#define TOUCH_YP A3
#define TOUCH_XM A1
#define TOUCH_YM A0
// Define the screen dimensions and colors
#define SCREEN_WIDTH 320
#define SCREEN_HEIGHT 240
#define CLOCK_POSITION_X 20
#define CLOCK_POSITION_Y 20
// Define the file explorer dimensions and colors
#define FILE_EXPLORER_POSITION_X 50
#define FILE_EXPLORER_POSITION_Y 50
#define FILE_EXPLORER_WIDTH 200
#define FILE_EXPLORER_HEIGHT 150
// Create an instance of the library for the TFT screen
UTFT myGLCD(TFT_RD, TFT_WR, TFT_RS, TFT_CS, TFT_RST);
// Create an instance of the library for the touch screen
URTouch myTouch(TOUCH_XP, TOUCH_YP, TOUCH_XM, TOUCH_YM, 300);
// Function to draw the clock widget
void drawClock() {
// Get the current time and date
int hours = getHours();
int minutes = getMinutes();
int seconds = getSeconds();
int day = getDay();
int month = getMonth();
int year = getYear();
// Draw the clock widget on the screen
myGLCD.print(hours, CLOCK_POSITION_X, CLOCK_POSITION_Y);
myGLCD.print(":", CLOCK_POSITION_X + 70, CLOCK_POSITION_Y);
myGLCD.print(minutes, CLOCK_POSITION_X + 90, CLOCK_POSITION_Y);
myGLCD.print(":", CLOCK_POSITION_X + 160, CLOCK_POSITION_Y);
myGLCD.print(seconds, CLOCK_POSITION_X + 180, CLOCK_POSITION_Y);
// Draw the date
myGLCD.print(day, CLOCK_POSITION_X + 50, CLOCK_POSITION_Y + 30);
myGLCD.print("/", CLOCK_POSITION_X + 70, CLOCK_POSITION_Y + 30);
myGLCD.print(month, CLOCK_POSITION_X + 90, CLOCK_POSITION_Y + 30);
myGLCD.print("/", CLOCK_POSITION_X + 110, CLOCK_POSITION_Y + 30);
myGLCD.print(year, CLOCK_POSITION_X + 130, CLOCK_POSITION_Y + 30);
// Function to draw the file explorer widget
void drawFileExplorer() {
// Draw the file explorer widget on the screen
myGLCD.fillRoundRect(FILE_EXPLORER_POSITION_X, FILE_EXPLORER_POSITION_Y, FILE_EXPLORER_POSITION_X + FILE_EXPLORER_WIDTH, FILE_EXPLORER_POSITION_Y + FILE_EXPLORER_HEIGHT );
myGLCD.print("File Explorer", FILE_EXPLORER_POSITION_X + 10,
FILE_EXPLORER_POSITION_Y + 10);
// Display the files and folders in the file explorer
// You will need to modify this based on your specific file system
// You can use the myGLCD.print() function to display the file and folder names
// Initialize the TFT screen
myGLCD.InitLCD();
myGLCD.clrScr();
// Initialize the touch screen
myTouch.InitTouch();
myTouch.setPrecision(PREC_MEDIUM);
// Check for touch input
if (myTouch.dataAvailable()) {
// Read the touch input
myTouch.read();
// Check if the touch input corresponds to the clock widget
if (myTouch.getX() >= CLOCK_POSITION_X &&
myTouch.getX() <= CLOCK_POSITION_X + 200 &&
myTouch.getY() >= CLOCK_POSITION_Y &&
myTouch.getY() <= CLOCK_POSITION_Y + 100) {
// Perform actions when clock widget is touched
// For example, display a menu or perform a specific action
// Check if the touch input corresponds to the file explorer widget
if (myTouch.getX() >= FILE_EXPLORER_POSITION_X &&
myTouch.getX() <= FILE_EXPLORER_POSITION_X + FILE_EXPLORER_WIDTH &&
myTouch.getY() >= FILE_EXPLORER_POSITION_Y &&
myTouch.getY() <= FILE_EXPLORER_POSITION_Y + FILE_EXPLORER_HEIGHT) {
// Perform actions when file explorer widget is touched
// For example, navigate through folders or open a file
// Update the clock widget every second
if (millis() % 1000 == 0) {
drawClock();
// it takes 10 hours to make code but still errors
