I want to try TMRpcm with SDFAT but the example of this library has given me error when compiling.
I have not changed anything and I installed the libraries : TMRpcm , SdFat , SdFatTestSuit .
This is the error
C:\Users\Gabo\Documents\Arduino\libraries\TMRpcm\TMRpcm.cpp: In member function 'void TMRpcm::createWavTemplate(char*, unsigned int)':
C:\Users\Gabo\Documents\Arduino\libraries\TMRpcm\TMRpcm.cpp:1608:5: error: 'SdVolume' was not declared in this scope
SdVolume vol;
C:\Users\Gabo\Documents\Arduino\libraries\TMRpcm\TMRpcm.cpp:1608:14: error: expected ';' before 'vol'
SdVolume vol;
C:\Users\Gabo\Documents\Arduino\libraries\TMRpcm\TMRpcm.cpp:1619:6: error: 'vol' was not declared in this scope
if(!vol.init(&card1)){}//Serial.println("card failed"); }
C:\Users\Gabo\Documents\Arduino\libraries\TMRpcm\TMRpcm.cpp:1620:21: error: 'vol' was not declared in this scope
if (!rut.openRoot(&vol)) {}//Serial.println("openRoot failed"); }
Error de compilación
I have encountered exactly the same problem with you. And I have uncomment #define ENABLE_RECORDING & #define SDFAT in the pcmConfig.h file. But it doesn't work.....
I'm experiencing errors trying to get the sdfat example running, using UNO R3, IDE 1.8.5.
I did define ENABLE_RECORDING and SDFAT too.
This is the error message:
Arduino: 1.8.5 (Linux), Board: "Arduino/Genuino Uno"
.../Arduino/libraries/TMRpcm/TMRpcm.cpp: In member function 'byte TMRpcm::metaInfo(boolean, char*, char*, byte)':
/home/jappie/Arduino/libraries/TMRpcm/TMRpcm.cpp:1381:18: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char* datStr = "LIST";
.../Arduino/libraries/TMRpcm/TMRpcm.cpp:1382:28: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
if(infoType == 1){datStr = "ID3 "; datStr[3] = 3;}
.../Arduino/libraries/TMRpcm/TMRpcm.cpp:1410:42: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char* tagNames[] = {"INAM","IART","IPRD"};
.../Arduino/libraries/TMRpcm/TMRpcm.cpp:1430:16: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
tagNames[0] = "TPE1"; tagNames[1] ="TIT2"; tagNames[2] ="TALB";
.../Arduino/libraries/TMRpcm/TMRpcm.cpp:1430:38: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
.../Arduino/libraries/TMRpcm/TMRpcm.cpp:1430:59: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
.../Arduino/libraries/TMRpcm/TMRpcm.cpp: In member function 'void TMRpcm::finalizeWavTemplate(char*)':
.../Arduino/libraries/TMRpcm/TMRpcm.cpp:1568:65: warning: narrowing conversion of '(fSize >> 16)' from 'long unsigned int' to 'byte {aka unsigned char}' inside { } [-Wnarrowing]
seek(4); byte data[4] = {lowByte(fSize),highByte(fSize), fSize >> 16,fSize >> 24};
.../Arduino/libraries/TMRpcm/TMRpcm.cpp:1568:77: warning: narrowing conversion of '(fSize >> 24)' from 'long unsigned int' to 'byte {aka unsigned char}' inside { } [-Wnarrowing]
.../Arduino/libraries/TMRpcm/TMRpcm.cpp: In member function 'void TMRpcm::createWavTemplate(char*, unsigned int)':
.../Arduino/libraries/TMRpcm/TMRpcm.cpp:1608:5: error: 'SdVolume' was not declared in this scope
SdVolume vol;
.../Arduino/libraries/TMRpcm/TMRpcm.cpp:1615:13: error: 'class Sd2Card' has no member named 'init'
if (!card1.init(SPI_FULL_SPEED,CSPin)) {
.../Arduino/libraries/TMRpcm/TMRpcm.cpp:1619:6: error: 'vol' was not declared in this scope
.../Arduino/libraries/TMRpcm/TMRpcm.cpp:1620:21: error: 'vol' was not declared in this scope
exit status 1
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
In some google search source I read somebody advising to add the SD.h library. So I tried adding this too:
#define SD_CHIP_SELECT_PIN 10 #include <SD.h>
I got some different error messages:
In file included from .../Arduino/Arduino sketches/sdfatExample/sdfatExample.ino:15:0:
.../Desktop/arduino-1.8.5/libraries/SD/src/SD.h:24:0: warning: "FILE_WRITE" redefined
#define FILE_WRITE (O_READ | O_WRITE | O_CREAT)
In file included from .../Arduino/libraries/SdFatmaster/src/FatLib/FatLib.h:27:0,
from .../Arduino/libraries/SdFatmaster/src/SdFat.h:33,
from.../Arduino/Arduino sketches/sdfatExample/sdfatExample.ino:12:
.../Arduino/libraries/SdFatmaster/src/FatLib/ArduinoFiles.h:39:0: note: this is the location of the previous definition
#define FILE_WRITE (O_RDWR | O_CREAT | O_AT_END)
In file included from.../Arduino/Arduino sketches/sdfatExample/sdfatExample.ino:15:0:
.../Desktop/arduino-1.8.5/libraries/SD/src/SD.h:62:3: error: 'SdVolume' does not name a type
SdVolume volume;
.../Arduino/Arduino sketches/sdfatExample/sdfatExample.ino: In function 'void setup()':
.../Arduino/Arduino sketches/sdfatExample/sdfatExample.ino:32:24: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
audio.play("song.wav");
.../Arduino/Arduino sketches/sdfatExample/sdfatExample.ino: In function 'void loop()':
.../Arduino/Arduino sketches/sdfatExample/sdfatExample.ino:40:38: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
case 'p': audio.play("song.wav"); break;
exit status 1
A day later I found out that the code compiles without problems when using the Arduino web IDE...
