Error In Uploading Code To Esp8266
Hey guys I Am Using An Esp8266 To Send Messages In Telegram.I Have provided the ssid and pass and the bot token and the recipient's chat Id.but the main problem here is Uploading The Code to Esp8266.It Says An Error And I Couldn't Solve It . Please solve my problem.I Have searched everywhere nothing seems to help.
The error is : a fatal estpool.py error occured: failed to connect to esp8266: timed out waiting for packet header
It would be very very very helpful if u could send me the solution
This is the code I used and I got it from a website.the website link also there at the start of the code.
  Rui Santos
  Complete project details at https://RandomNerdTutorials.com/telegram-esp8266-nodemcu-motion-detection-arduino/
  Project created using Brian Lough's Universal Telegram Bot Library: https://github.com/witnessmenow/Universal-Arduino-Telegram-Bot
#include <ESP8266WiFi.h>
#include <WiFiClientSecure.h>
#include <UniversalTelegramBot.h>
#include <ArduinoJson.h>
// Replace with your network credentials
const char* ssid = "REPLACE_WITH_YOUR_SSID";
const char* password = "REPLACE_WITH_YOUR_PASSWORD";
// Initialize Telegram BOT
#define BOTtoken "XXXXXXXXXX:XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"  // your Bot Token (Get from Botfather)
// Use @myidbot to find out the chat ID of an individual or a group
// Also note that you need to click "start" on a bot before it can
// message you
#define CHAT_ID "XXXXXXXXXX"
X509List cert(TELEGRAM_CERTIFICATE_ROOT);
WiFiClientSecure client;
UniversalTelegramBot bot(BOTtoken, client);
const int motionSensor = 14; // PIR Motion Sensor
bool motionDetected = false;
// Indicates when motion is detected
void ICACHE_RAM_ATTR detectsMovement() {
  //Serial.println("MOTION DETECTED!!!");
  motionDetected = true;
  configTime(0, 0, "pool.ntp.org");      // get UTC time via NTP
  client.setTrustAnchors(&cert); // Add root certificate for api.telegram.org
  // PIR Motion Sensor mode INPUT_PULLUP
  pinMode(motionSensor, INPUT_PULLUP);
  // Set motionSensor pin as interrupt, assign interrupt function and set RISING mode
  attachInterrupt(digitalPinToInterrupt(motionSensor), detectsMovement, RISING);
  // Attempt to connect to Wifi network:
  Serial.print("Connecting Wifi: ");
  Serial.println(ssid);
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.print("IP address: ");
  bot.sendMessage(CHAT_ID, "Bot started up", "");
  if(motionDetected){
    bot.sendMessage(CHAT_ID, "Motion detected!!", "");
    Serial.println("Motion Detected");
The issue is not in the code (it compiled) but in the way you have connected the ESP or which USB port you have selected.
What kind of ESP8266 do you have and how have you connected it ?
Depending on the ESP8266 board you may need to hold down a boot/flash button while you try to upload the code. Please link to the board you are using.
