Error in uploading coding in water level sensor
const int trigPin = 9;
const int echoPin = 11;
const int LED1 = A0;
const int LED2 = A1;
const int LED3 = A2;
int duration = 0;
int distance = 0;
  pinMode(trigPin , OUTPUT);
  pinMode(echoPin , INPUT);
  pinMode(LED1 , OUTPUT);//red
  pinMode(LED2 , OUTPUT);//yellow
  pinMode(LED3 , OUTPUT);//green
  pinMode(8, OUTPUT);//buzzer
  pinMode(0, OUTPUT);// pin g
  pinMode(1, OUTPUT);// pin f
  pinMode(2, OUTPUT);// pin e
  pinMode(3, OUTPUT);// pin
  pinMode(4, OUTPUT);// pin
  pinMode(5, OUTPUT);// pin
  pinMode(6, OUTPUT);// pin
  pinMode(7, OUTPUT);//
  digitalWrite(7, 0);  // Make pin "dp" off in all digit
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH);
  distance = duration/58.2;
  if ( distance <= 7 )//high level
    digitalWrite(LED1, HIGH);
    tone(8, 200);
       // Display 'H'
    digitalWrite(0, 1);
    digitalWrite(1, 1);
    digitalWrite(2, 1);
    digitalWrite(3, 0);
    digitalWrite(4, 1);
    digitalWrite(5, 1);
    digitalWrite(6, 0);
    digitalWrite(LED1, LOW);
    noTone(8);
  if ( distance <= 25 )//medium level
    digitalWrite(LED2, HIGH);
     // Display '-'
    digitalWrite(0, 1);
    digitalWrite(1, 0);
    digitalWrite(2, 0);
    digitalWrite(3, 0);
    digitalWrite(4, 0);
    digitalWrite(5, 0);
    digitalWrite(6, 0);
    digitalWrite(LED2, LOW);
  if ( distance <= 50 )//low level
    digitalWrite(LED3, HIGH);
     // Display 'L'
    digitalWrite(0, 0);
    digitalWrite(1, 0);
    digitalWrite(2, 0);
    digitalWrite(3, 1);
    digitalWrite(4, 1);
    digitalWrite(5, 0);
    digitalWrite(6, 0);
    digitalWrite(LED3, LOW);
After we use above coding, we got this error.
Sketch uses 4042 bytes (12%) of program storage space. Maximum is 32256 bytes.
Global variables use 205 bytes (10%) of dynamic memory, leaving 1843 bytes for local variables. Maximum is 2048 bytes.
Prototype :
Using Arduino using ultrasonic sensor to measure the water level (3 condition) , high (H) , medium (-) & low (L) . H,-, L display on 7 segment. Buzzer will turn on when the level is H. Led red for H, led yellow for - , led green for L.
Welcome
Pins 0 and 1 must be free for uploading a new program, they are connected to the USB-Serial converter
do you mean , delete this line or change to another pin?
do you mean like this ?
pinMode(2, OUTPUT);// pin g
  pinMode(3, OUTPUT);// pin f
  pinMode(4, OUTPUT);// pin e
  pinMode(5, OUTPUT);// pin d
  pinMode(6, OUTPUT);// pin c
  pinMode(7, OUTPUT);// pin b
  pinMode(8, OUTPUT);// pin a
  pinMode(9, OUTPUT);//
  digitalWrite(9, 0);  // Make pin "dp" off in all digit
Yes I suggest to use other pins
Pins 0 and 1 are used for Serial communication, if you want to use these pins for something else, then you should not use Serial.begin, and you have to disconnect wires from those pins every time you want to upload a new program
