I'm trying to use Digispark attiny85 board and running into issues uploading the sketch.
The drivers are correctly installed. I have followed this page as a reference.
Below the sketch and the error message.
Thanks for any help
Thanks for any help
Please copy and paste the test from the screens rather than screen shots which are practically unreadable
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\LAB C Student 8\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\LAB C Student 8\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\LAB C Student 8\Documents\Arduino\libraries -fqbn=digistump:avr:digispark-pro -ide-version=10813 -build-path C:\Users\LAB C Student 8\AppData\Local\Temp\arduino_build_518499 -warnings=none -build-cache C:\Users\LAB C Student 8\AppData\Local\Temp\arduino_cache_128152 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\LAB C Student 8\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5 -prefs=runtime.tools.avr-gcc-4.8.1-arduino5.path=C:\Users\LAB C Student 8\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5 -prefs=runtime.tools.micronucleus.path=C:\Users\LAB C Student 8\AppData\Local\Arduino15\packages\digistump\tools\micronucleus\2.0a4 -prefs=runtime.tools.micronucleus-2.0a4.path=C:\Users\LAB C Student 8\AppData\Local\Arduino15\packages\digistump\tools\micronucleus\2.0a4 -verbose C:\Users\LAB C Student 8\AppData\Local\Temp\arduino_modified_sketch_562196\Blink.ino
Using board 'digispark-pro' from platform in folder: C:\Users\LAB C Student 8\AppData\Local\Arduino15\packages\digistump\hardware\avr\1.6.7
Using core 'pro' from platform in folder: C:\Users\LAB C Student 8\AppData\Local\Arduino15\packages\digistump\hardware\avr\1.6.7
Detecting libraries used...
"C:\\Users\\LAB C Student 8\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\4.8.1-arduino5/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -w -x c++ -E -CC -mmcu=attiny167 -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_DIGISPARKPRO -DARDUINO_ARCH_AVR "-IC:\\Users\\LAB C Student 8\\AppData\\Local\\Arduino15\\packages\\digistump\\hardware\\avr\\1.6.7\\cores\\pro" "-IC:\\Users\\LAB C Student 8\\AppData\\Local\\Arduino15\\packages\\digistump\\hardware\\avr\\1.6.7\\variants\\pro" "C:\\Users\\LAB C Student 8\\AppData\\Local\\Temp\\arduino_build_518499\\sketch\\Blink.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Generating function prototypes...
"C:\\Users\\LAB C Student 8\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\4.8.1-arduino5/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -w -x c++ -E -CC -mmcu=attiny167 -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_DIGISPARKPRO -DARDUINO_ARCH_AVR "-IC:\\Users\\LAB C Student 8\\AppData\\Local\\Arduino15\\packages\\digistump\\hardware\\avr\\1.6.7\\cores\\pro" "-IC:\\Users\\LAB C Student 8\\AppData\\Local\\Arduino15\\packages\\digistump\\hardware\\avr\\1.6.7\\variants\\pro" "C:\\Users\\LAB C Student 8\\AppData\\Local\\Temp\\arduino_build_518499\\sketch\\Blink.ino.cpp" -o "C:\\Users\\LAB C Student 8\\AppData\\Local\\Temp\\arduino_build_518499\\preproc\\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\LAB C Student 8\\AppData\\Local\\Temp\\arduino_build_518499\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\LAB C Student 8\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\4.8.1-arduino5/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -MMD -mmcu=attiny167 -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_DIGISPARKPRO -DARDUINO_ARCH_AVR "-IC:\\Users\\LAB C Student 8\\AppData\\Local\\Arduino15\\packages\\digistump\\hardware\\avr\\1.6.7\\cores\\pro" "-IC:\\Users\\LAB C Student 8\\AppData\\Local\\Arduino15\\packages\\digistump\\hardware\\avr\\1.6.7\\variants\\pro" "C:\\Users\\LAB C Student 8\\AppData\\Local\\Temp\\arduino_build_518499\\sketch\\Blink.ino.cpp" -o "C:\\Users\\LAB C Student 8\\AppData\\Local\\Temp\\arduino_build_518499\\sketch\\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
"C:\\Users\\LAB C Student 8\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\4.8.1-arduino5/bin/avr-gcc" -c -g -Os -w -ffunction-sections -fdata-sections -MMD -mmcu=attiny167 -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_DIGISPARKPRO -DARDUINO_ARCH_AVR "-IC:\\Users\\LAB C Student 8\\AppData\\Local\\Arduino15\\packages\\digistump\\hardware\\avr\\1.6.7\\cores\\pro" "-IC:\\Users\\LAB C Student 8\\AppData\\Local\\Arduino15\\packages\\digistump\\hardware\\avr\\1.6.7\\variants\\pro" "C:\\Users\\LAB C Student 8\\AppData\\Local\\Arduino15\\packages\\digistump\\hardware\\avr\\1.6.7\\cores\\pro\\WInterrupts.c" -o "C:\\Users\\LAB C Student 8\\AppData\\Local\\Temp\\arduino_build_518499\\core\\WInterrupts.c.o"
Archiving built core (caching) in: C:\Users\LAB C Student 8\AppData\Local\Temp\arduino_cache_128152\core\core_digistump_avr_digispark-pro_ef23a97e10aca7821c1ab1e59eecb29e.a
Linking everything together...
"C:\\Users\\LAB C Student 8\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\4.8.1-arduino5/bin/avr-gcc" -Os -Wl,--gc-sections -mmcu=attiny167 -o "C:\\Users\\LAB C Student 8\\AppData\\Local\\Temp\\arduino_build_518499/Blink.ino.elf" "C:\\Users\\LAB C Student 8\\AppData\\Local\\Temp\\arduino_build_518499\\sketch\\Blink.ino.cpp.o" "C:\\Users\\LAB C Student 8\\AppData\\Local\\Temp\\arduino_build_518499\\core\\core.a" "-LC:\\Users\\LAB C Student 8\\AppData\\Local\\Temp\\arduino_build_518499" -lm
"C:\\Users\\LAB C Student 8\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\4.8.1-arduino5/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\LAB C Student 8\\AppData\\Local\\Temp\\arduino_build_518499/Blink.ino.elf" "C:\\Users\\LAB C Student 8\\AppData\\Local\\Temp\\arduino_build_518499/Blink.ino.eep"
"C:\\Users\\LAB C Student 8\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\4.8.1-arduino5/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\LAB C Student 8\\AppData\\Local\\Temp\\arduino_build_518499/Blink.ino.elf" "C:\\Users\\LAB C Student 8\\AppData\\Local\\Temp\\arduino_build_518499/Blink.ino.hex"
"C:\\Users\\LAB C Student 8\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\4.8.1-arduino5/bin/avr-size" -A "C:\\Users\\LAB C Student 8\\AppData\\Local\\Temp\\arduino_build_518499/Blink.ino.elf"
Sketch uses 912 bytes (6%) of program storage space. Maximum is 14844 bytes.
Global variables use 9 bytes of dynamic memory.
C:\Users\LAB C Student 8\AppData\Local\Arduino15\packages\digistump\tools\micronucleus\2.0a4/launcher -cdigispark --timeout 60 -Uflash:w:C:\Users\LAB C Student 8\AppData\Local\Temp\arduino_build_518499/Blink.ino.hex:i
Running Digispark Uploader...
Plug in device now... (will timeout in 60 seconds)
> Please plug in the device ...
> Press CTRL+C to terminate the program.
> Device is found!
connecting: 16% complete
connecting: 22% complete
connecting: 28% complete
connecting: 33% complete
> Device has firmware version 1.6
> Available space for user applications: 6012 bytes
> Suggested sleep time between sending pages: 8ms
> Whole page count: 94 page size: 64
> Erase function sleep duration: 752ms
> Error opening C:\Users\L: No such file or directory
> Error loading or parsing hex file.
Invalid library found in C:\Users\LAB C Student 8\Documents\Arduino\libraries\MAX30100-master: no headers files (.h) found in C:\Users\LAB C Student 8\Documents\Arduino\libraries\MAX30100-master
Are there any files in this folder ?
How was the library installed ?
UKHeliBob:
yes,but i didn't use this library in my sketch.
Here is my sketch
// initialize digital pin LED_BUILTIN as an output.
pinMode(1, OUTPUT);
// the loop function runs over and over again forever
digitalWrite(1, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(1, LOW); // turn the LED off by making the voltage LOW
True. That was a bit of a sideshow and not the main problem, but you should put it right anyway
Can you upload a very simple sketch, such as the BareMinimum example ?
Which board have you got selected in the IDE ?
I have tried to upload the following the same error.
I tried with these two boards
digispark(default -16.5Mhz)
digispark pro(default 16Mhz)
