error in uploading sketch
i have an arduino uno ATMEGA328P. from www.arduino.org
i tried to configure the COM ports and the boards also but still there in an error in uploading the sketch.
the below error message appears:
" arduino-builder/arduino-builder -compile -core-api-version 10611 -build-path /tmp/757328429 -hardware arduino-builder/hardware -hardware arduino-builder/packages/cores -tools arduino-builder/tools -tools arduino-builder/packages/tools -built-in-libraries arduino-builder/latest -libraries /tmp/124143750/pinned -libraries /tmp/124143750/custom -fqbn arduino:avr:uno -verbose=false /tmp/124143750/Blink
Sketch uses 928 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x64
Could not program the board
I am experiencing this as well. Are you using Linux?
(deleted)
