error in using overloaded constructor
I'm a new arduino developer and I'm implementing my neural net libraries for the pololu robot.
I have a weird error when trying to use a class with an overloaded constructor.
Basically the .h looks like this:
class NeuronBP
  public:
    // ====================  LIFECYCLE   =========================================
    /*! Constructor f,q */
    NeuronBP(double f=DEF_F, double q=DEF_Q);
    /*! Constructor void*/
    NeuronBP();
and the c++ code looks like:
NeuronBP::NeuronBP(double f, double q)
  reset();
  normalize_ = true;
  burst_ = false;
  setFQ(f,q);
/** Constructor that sets frequency and quality.
 *      @param  f double - The frequency.
 *      @param  q double - The quality.
NeuronBP::NeuronBP()
  NeuronBP(NeuronBP::DEF_F,NeuronBP::DEF_Q);
The library is succesfully compiled and I can use it in this way:
void loop()                     // run over and over again
  NeuronBP nrnbp(0.2,0.5);
  for(double k=1.0;k<10.0;k=k+10.0)
   nrnbp.calculate(k);
but when I try to use:
  NeuronBP nrnbp();
   nrnbp.calculate(k);
The compiler says:
In function 'void loop()':
error: request for member 'calculate' in 'nrnbp', which is of non-class type 'NeuronBP ()()
it seems it considers two classes within the 2 different constructors.
Is it because i can't use overloading in classes?
Change:
NeuronBP nrnbp();
to:
NeuronBP nrnbp;
Putting the () after it actually makes nrnbp a pointer to a function that returns a NeuronBP, rather than just a variable of type NeuronBP.
Also, you might have problems because it's ambiguous to have both a default constructor and a constructor in which all the parameters are optional. You should be able to just delete the default constructor (or make one of the parameters non-optional in the other constructor).
It's true: mine was a very stupid mistake!
The corrected version now looks like:
NeuronBP.h
class NeuronBP
  private:
    static const double  DEF_F = 0.1;
    static const double  DEF_Q = 0.51;
  public:
and is working and compiling now I only have to test it ;D
