Error in void loop()
int led=13;
int led2=12;
int on_time=1000;
int off_time=1000;
pinMode(led, OUTPUT);
pinMode(led2, OUTPUT);
digitalWrite(led, LOW);
for(int a=1;a<=5;a=a+)
digitalWrite(led, HIGH);
delay(on_time);
digitalWrite(led,LOW);
delay(off_time);
when i try to upload this code i am getting an error compiling
sketch_aug24c.ino: In function ‘void loop()’:
sketch_aug24c.ino:21:22: error: expected primary-expression before ‘)’ token
for(int a=1;a<=5;a++)
oh thank you it worked
C ++ syntax is very important and easy to get wrong if you're just starting out.
Double-check what you've written when something doesn't work the way you expect
Now increment 5 to 10, or try it without the for loop.
Why don't you notice any difference?
const int led=13;
const int on_time=1000;
const int off_time=1000;
   delay(on_time);
   delay(off_time);
