error in whole programming
hi guy, need help in this programming
got error in the " Wire.send"
#include <Wire.h>
#include <EEPROM.h>
#define MAX_NO_CARDS 102
#define waitingLED 6
#define successLED 7
#define failureLED 5
int toggleState = 0;    // state of the toggling LED
long toggleTime = 0;    // delay time of the toggling LED
byte tag[4];            // tag serial numbers are 4 bytes long
  Wire.begin();                      // join i2c bus
  Serial.begin(9600);                // set up serial port
  Wire.beginTransmission(0x42);      // the RFID reader's address is 42
  Wire.send(0x01);                   // Length
  Wire.send(0x80);                   // reset reader
  Wire.send(0x81);                   // Checksum
  Wire.endTransmission();
  // initialize the LEDs:
  pinMode(waitingLED, OUTPUT);
  pinMode(successLED, OUTPUT);
  pinMode(failureLED, OUTPUT);
  // print user instructions serially:
  Serial.println("n - add card to database");
  Serial.println("c - clear entire database");
  Serial.println("d - delete card from database");
  Serial.println("p - print database");
  // delay to allow reader startup time:
  delay(2000);
  if (Serial.available() > 0) {
    // read the latest byte:
    char incomingByte = Serial.read();
    switch (incomingByte) {
    case 'n':            // if user enters 'n' then store tag number
      seekNewTag();
    case 'c':
      eraseEEPROM();    // if user enters 'c' then erase database
      Serial.println("Database deleted");
    case 'd':           // if user enters 'd' then delete the last tag
      seekAndDeleteTag();
    case'p':            // if user enters 'p' then print the database
      printTags();
  else {
    //if there's no serial data coming in,
    // the default action is to seek new tags:
    seekNewTag();
  // delay before next command to the reader:
  delay(200);
void eraseEEPROM(){
  for(int i = 0; i < 512; i++){
    EEPROM.write(i, 0);
void writeTag(int startingAddress, byte byte0, byte byte1, byte byte2, byte byte3){
  EEPROM.write( startingAddress*5, byte(1));
  EEPROM.write(startingAddress*5+1, byte0);
  EEPROM.write(startingAddress*5+2, byte1);
  EEPROM.write(startingAddress*5+3, byte2);
  EEPROM.write(startingAddress*5+4, byte3);
// delete tag from a specified location
void deleteTag(int startingAddress){
  EEPROM.write( startingAddress*5, byte(0));
  EEPROM.write(startingAddress*5+1, byte(0));
  EEPROM.write(startingAddress*5+2, byte(0));
  EEPROM.write(startingAddress*5+3, byte(0));
  EEPROM.write(startingAddress*5+4, byte(0));
// find the first empty entry in the database:
int findEmptyTag(){
  for (int startingAddress = 0; startingAddress< MAX_NO_CARDS; startingAddress++){
    byte value = EEPROM.read(startingAddress*5);
    if (value == byte(0)) {
      return(startingAddress);
  return(200);
// print the entire database
void printTags(){
  for (int thisTag = 0; thisTag< MAX_NO_CARDS; thisTag++){
    printOneTag(thisTag);
// print a single tag given the tag's address:
void printOneTag(int address) {
  Serial.print(address);
  Serial.print(":");
  for (int offset = 1; offset < 5; offset++) {
    int thisByte = int(EEPROM.read(address*5+offset));
    // if the byte is less than 16, i.e. only one hex character
    // add a leading 0:
    if (thisByte < 0x10) {
      Serial.print("0");
    // print the value:
    Serial.print(thisByte,HEX);
  // add a final linefeed and carriage return:
//lookup tag in the database:
int lookupTag(byte byte0, byte byte1, byte byte2, byte byte3){
  for (int thisCard = 0; thisCard< MAX_NO_CARDS; thisCard++){
    byte value = EEPROM.read(thisCard*5);
    if (value != byte(0)){                    //it is a valid tag
      //see if all four bytes are the same as the ones we're looking for
      if(byte0 == EEPROM.read(thisCard*5+1) && byte1 == EEPROM.read(thisCard*5+2)
        && byte2 == EEPROM.read(thisCard*5+3) && byte3 == EEPROM.read(thisCard*5+4)) {
        return(thisCard);
  // if you don't find the tag, return 200;
  return(200);
int getTag(){
  byte count = 0;
  byte valid = 0;
  byte byteFromReader = 0;
  Wire.send(0x82);           // Seek for tags
  Wire.send(0x83);           // Checksum
  delay(100);
  Wire.requestFrom(0x42, 8); // get data (8 bytes) from reader
  count = 0;                 // keeps track of which byte it is in the response from the reader
  valid = 0;                 // used to indicate that there is a tag there
  while(Wire.available())  { // while data is coming from the reader
    byteFromReader = Wire.receive();
    // no RFID found: reader sends character 2:
    if ((count == 0) && (byteFromReader == 2)) {
      return(0);
    if ((count == 0) && (byteFromReader== 6)) {
      //if reader sends 6, the tag serial number is coming:
      valid = 1;
    count++;
    if ((valid == 1) && (count > 3) && (count < 8)) {
      // strip out the header bytes  :
      tag[count-4] = byteFromReader;
    // all four bytes received: tag serial number complete:
    if ((valid == 1) && (count == 8)) {
      return(1);
void seekNewTag() {
  Serial.println("Waiting for card");
  while(getTag() == 0){
    // wait for tag
    if (millis() - toggleTime > 1000) {
      toggle(waitingLED);
      toggleTime  = millis();
    // unless you get a byte of serial data,
    if (Serial. available()) {
      // break out of the while loop
      // and out of the seekNewTag() method:
      return;
  // look it up in the database:
  int tagToCheck = lookupTag(tag[0], tag[1], tag[2], tag[3]);
  if (tagToCheck != 200){
    Serial.println("That tag is already stored");
    printOneTag(tagToCheck);
  else {
    int emptyTagLocation = findEmptyTag();
    if (emptyTagLocation != 200){
      writeTag(emptyTagLocation, tag[0], tag[1], tag[2], tag[3]);
      Serial.println("That tag is new");
      printOneTag(emptyTagLocation);
      blink(successLED, 100, 1);
    else {
      Serial.println("Maximum number of cards stored");
      blink(failureLED, 50, 10);
void seekAndDeleteTag() {
  Serial.println("Deleting the next card");
    // do nothing; wait for tag
      // and out of the method:
      return;
  int tagToDelete = lookupTag(tag[0], tag[1], tag[2], tag[3]);
  if (tagToDelete == 200){
    Serial.print("That tag is not stored");
  else {
    deleteTag(tagToDelete);
void toggle(int thisLED) {
  toggleState = !toggleState;
  digitalWrite(thisLED, toggleState);
void blink(int thisLED, int interval, int count) {
  for (int i = 0; i < count; i++) {
    digitalWrite(thisLED, HIGH);
    delay(interval/2);
    digitalWrite(thisLED, LOW);
    delay(interval/2);
What error?
Pete
they send me this As of Arduino 1.0, the Wire.send() function was renamed to Wire.write() for consistency with other libraries.
sketch_mar14b:19: error: 'class TwoWire' has no member named 'send'
sketch_mar14b:20: error: 'class TwoWire' has no member named 'send'
sketch_mar14b.ino: In function 'int getTag()':
sketch_mar14b:149: error: 'class TwoWire' has no member named 'send'
sketch_mar14b:150: error: 'class TwoWire' has no member named 'send'
sketch_mar14b:151: error: 'class TwoWire' has no member named 'send'
sketch_mar14b:160: error: 'class TwoWire' has no member named 'receive'
As of Arduino 1.0, the Wire.receive() function was renamed to Wire.read() for consistency with other libraries.
they send me this wan
That's strange. It compiles for me on a Nano using Arduino 1.0.5
Anyway, just change .send to .write
Pete
error in byteFromReader = Wire.receive();
got error in this
So, why don't you do some hunt-and-peck typing, and change receive() to read()? You are being told EXACTLY what you need to change.
