Error - "incompatible types in assignment of 'int' to 'char[2]'
I am getting the error "incompatible types in assignment of 'int' to 'char[2]' ... How can I fix this?
char CoinRead[2];
Serial.println("Virtual Coin Acceptor Ready");
Serial.readBytes(CoinRead, 2);
 if(CoinRead>0) {
    if(CoinRead==05){
      Serial.println("Five Cents Inserted");
      CoinRead = 00;
    }else{
      Serial.print(CoinRead);
      Serial.print( );
      Serial.println("Failed To Recognise");
      CoinRead = 0;
How can I fix this?
CoinRead = 00;Don't do this.
00 is an 'int'. The compiler is telling you that you cannot assign it to a char array.
It isn't clear to me what you intend.
How about if(CoinRead[0]=='0' && CoinRead [1] == '5'){.
This assumes the coin mech sends ASCII.
Of course, the "CoinRead > 0" will have to go.
Will this set it to 0?
PinballCoder018:
No, I've set out how you could try the comparison.
If you want more help, you need to provide more detail, otherwise I risk wasting time.
What I am trying to do is after the value that the user types in is read and recognized then I want to value of ‘char[2]’ to set to ‘00’ or ‘0’. The user needs to be able to type in a two digit number.
I've shown you how to compare two characters.
How about you figure out how to assign to two characters?
OK...Sure
