Error Initializing SD Card on 2650 R3 and Network Shield v6
I am having issues with the SD card initializing when the device is first powered up. If i eject the card and reinsert it while the device is running then it will start working.
I am running genuine arduino 2650 and Ethernet shield R3 (v6).
What is really strange is if i use the networking with the sd card and reinsert the card after boot up I have no issues serving web pages off of it.
Here is the code i am running:
const int chipSelect = 4;
    while (!Serial) {
        ; // wait for serial port to connect. Needed for Leonardo only
    Serial.print("SS: ");
    Serial.println(SS_PIN);
    Serial.print("MISO: ");
    Serial.println(SPI_MISO_PIN);
    Serial.print("MOSI: ");
    Serial.println(SPI_MOSI_PIN);
    Serial.print("SCK: ");
    Serial.println(SPI_SCK_PIN);
    Serial.print("PIN4: ");
    Serial.println(PIN4);
    Serial.print("\nInitializing SD card...");
    // On the Ethernet Shield, CS is pin 4. It's set as an output by default.
    // Note that even if it's not used as the CS pin, the hardware SS pin
    // (10 on most Arduino boards, 53 on the Mega) must be left as an output
    // or the SD library functions will not work.
    pinMode(53, OUTPUT);     // change this to 53 on a mega
    // we'll use the initialization code from the utility libraries
    // since we're just testing if the card is working!
    if (!card.init(SPI_HALF_SPEED, chipSelect)) {
        Serial.println("initialization failed. Things to check:");
        Serial.println("* is a card is inserted?");
        Serial.println("* Is your wiring correct?");
        Serial.println("* did you change the chipSelect pin to match your shield or module?");
        return;
    else {
        Serial.println("Wiring is correct and a card is present.");
    // print the type of card
    Serial.print("\nCard type: ");
    switch (card.type()) {
    case SD_CARD_TYPE_SD1:
        Serial.println("SD1");
    case SD_CARD_TYPE_SD2:
        Serial.println("SD2");
    case SD_CARD_TYPE_SDHC:
        Serial.println("SDHC");
    default:
        Serial.println("Unknown");
You must disable all other SPI devices before starting any of them. Disable the w5100 SPI interface before starting the SD card.
  // disable w5100 SPI
  pinMode(10, OUTPUT);
  digitalWrite(10, HIGH);
  // now do the rest of your setup
