error: "Invalid use of void expression" when using attachInterrupt
Hi everyone,
I’m quite new with Arduino (writing simple programs for a month now) and for a small project I need to write one (big) sketch including several smaller sketches (e.g. a color sensor and a NFC reader).
Individual, the sketches will compile and run correctly, but when I want to put them together I get an error using attachInterrupt, namely: Invalid use of void expression.
Does anyone know how to fix this error and perhaps the background information so I can avoid this error in the future?
Thanks in advance!
P.S. I put a part my code down below and the individual sketches as a attachment.
// Include Colorsensor Libraries
  #include <TimerOne.h>
// Colorsensor Values
  #define S0     6   // Please notice the Pin's define
  #define S1     5
  #define S2     4
  #define S3     3
  #define OUT    2
  int   g_count = 0;    // count the frequecy
  int   g_array[3];     // store the RGB value
  int   g_flag = 0;     // filter of RGB queue
  float g_SF[3];        // save the RGB Scale factor
  int value[3];         // used to determine definite color
  char color;
  Colorsensor_setup();
void loop() {// This will be filled in later, I'm still assemblying the code
//Tab 2, Colorsensor functions
int Colorsensor_setup()
  // Values and pins used by Colorsensor
  #define S0     6
  #define S1     5
  #define S2     4
  #define S3     3
  #define OUT    2
  char color;           // char including the definite color
  // PIECE THAT INCLUDES THE ERROR WHEN UNCOMMENTED
  TSC_Init();
  Timer1.initialize();             // default is 1s
  Timer1.attachInterrupt(TSC_Callback(g_count, g_flag, g_array));
  attachInterrupt(0, TSC_Count(g_count), RISING);
  delay(4000);
  for (int i=0; i<3; i++){
    Serial.println(g_array[i]);
  g_SF[0] = 255.0/ g_array[0];     //R Scale factor
  g_SF[1] = 255.0/ g_array[1];     //G Scale factor
  g_SF[2] = 255.0/ g_array[2];     //B Scale factor
  Serial.print("R Scale Factor:");
  Serial.println(g_SF[0]);
  Serial.print("G Scale Factor:");
  Serial.println(g_SF[1]);
  Serial.print("B Scale Factor:");
  Serial.println(g_SF[2]);
// Init TSC230 and setting Frequency.
void TSC_Init()
  pinMode(S0, OUTPUT);
  pinMode(S1, OUTPUT);
  pinMode(S2, OUTPUT);
  pinMode(S3, OUTPUT);
  pinMode(OUT, INPUT);
  digitalWrite(S0, LOW);  // OUTPUT FREQUENCY SCALING 2%
  digitalWrite(S1, HIGH);
// Select the filter color
void TSC_FilterColor(int Level01, int Level02)
  if(Level01 != 0){
    Level01 = HIGH;
  if(Level02 != 0){
    Level02 = HIGH;
  digitalWrite(S2, Level01);
  digitalWrite(S3, Level02);
void TSC_Count(int g_count)
  g_count ++ ;
void TSC_Callback(int g_count, int g_flag, int *g_array)
  switch(g_flag)
    case 0:
         Serial.println("->WB Start");
         TSC_WB(LOW, LOW, g_count, g_flag);                   //Filter without Red
    case 1:
         Serial.print("->Frequency R=");
         Serial.println(g_count);
         g_array[0] = g_count;
         TSC_WB(HIGH, HIGH, g_count, g_flag);                 //Filter without Green
    case 2:
         Serial.print("->Frequency G=");
         g_array[1] = g_count;
         TSC_WB(LOW, HIGH, g_count, g_flag);                  //Filter without Blue
    case 3:
         Serial.print("->Frequency B=");
         Serial.println("->WB End");
         g_array[2] = g_count;
         TSC_WB(HIGH, LOW, g_count, g_flag);                  //Clear(no filter)
   default:
         g_count = 0;
int TSC_WB(int Level0, int Level1, int g_count, int g_flag)   //White Balance
  g_count = 0;
  g_flag ++;
  TSC_FilterColor(Level0, Level1);
  Timer1.setPeriod(1000000);              // set 1s period
Colorsensor.ino (2.85 KB)
NFC.ino (1.43 KB)
Testcode.ino (1.08 KB)
attachInterrupt must take a function taking no arguments as its second parameter. You are not supplying that. Also, by supplying an argument (g_count) you are calling the function, not supplying its address.
See: Gammon Forum : Electronics : Microprocessors : Function pointers / function callbacks / function variables.
Dear Nick,
Thanks for answering so quick. I think I understand and indeed my sketch don't give compile errors anymore. Btw, you're site helped a lot.
Thanks again!
