Hello guys who knows why I get this error, and what should I do?
I am a Arduino Due.
but when I put Tools -> Board -> Ardino Uno everything works
I get the same error with Arduino Due when I put other libraries.
I am a Arduino Due.
Post your whole code.
#include <IRremote.h>
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
String stato;void setup()
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
irrecv.enableIRIn(); // Start the receiver
}void loop() {
if (irrecv.decode(&results)) {
Serial.println(results.value);if(results.value == 16767525){
stato = "acceso1";
digitalWrite(2, HIGH);
else if (results.value == 16773645) {
stato = "acceso2";
digitalWrite(3, HIGH);
else if (results.value == 16763445) {
stato = "acceso3";
digitalWrite(4, HIGH);
else if (results.value == 4294967295) {
stato = "mantieniacceso";
else {
stato = "spento";
};if(stato == "acceso1"){
else if (stato == "acceso2") {
else if (stato == "acceso3") {
else if (stato == "mantieniacceso") {
else if (stato == "spento") {
digitalWrite(4, LOW);
digitalWrite(3, LOW);
digitalWrite(2, LOW);
};irrecv.resume(); // Receive the next value
I'm not sure but i think the current IRremote Lib will not work with the Due at all.
I'm also searching a way to make it work together by the way, so any help is welcome ![]()
The library seems to use avr specific interrupt functions. It needs to be rewritten to work with Due.
