error: ISO C++ says that these are ambiguous. . .
I'm getting this error whenever I use a variable to define an address using the requestFrom function in the Wire.h library:
"error: ISO C++ says that these are ambiguous, even though the worst conversion for the first is better than the worst conversion for the second:
. . . libraries\Wire/Wire.h:52: note: candidate 2: uint8_t TwoWire::requestFrom(uint8_t, uint8_t)"
Code in question:
#include <Wire.h>
byte max6965 = 32; // write to device 40h (01000000 binary), shifted gives 0x20
Wire.beginTransmission(max6965);
Wire.send(address);
Wire.endTransmission();
Wire.requestFrom(max6965, 1); //TROUBLED LINE
if(1 <= Wire.available()) // if 1 byte was received
reading = Wire.receive(); // receive high byte (overwrites previous reading)
Serial.print("RAM Holds: ");
Serial.println(reading); // print the reading
Serial.println("Sorry, the LED ram appears to hold no data");
Serial print stuff is just for debugging. Any ideas? I'm guessing this has to do with how the variables are handled in the actual Wire.h library. I tried declaring max6965 as an int or a byte when passing it into the wire.requestFrom function but it didn't help.
You need to turn the "byte max6965" to an "int max6965"
I just with some of my code, and got the same error. I can't really try with your code.. seeing as it's not really full code. :smiley:
But next time you post some code, you should make use of the "#" sign on the toolbar when typing. This just makes your code easy to read, and gives it a scrollbox so it doesn't take up 3 pages of your screen. (longer code of course:P)
But let us know if you have anymore problems!:slight_smile:
noob mistake :slight_smile: Works perfectly now.
Thanks for the help, I'll format things correctly in the future. I chopped up the code because I didn't want people getting hung up on other things.
Thanks for your help!
:smiley:
No problem, I know how it goes. :slight_smile: But it's not always a problem in just that piece of code! Might save you from having to post again.
Oh and welcome to the wonderful world of Arduino! :sunglasses:
Actually, casting either will work:
Wire.requestFrom((int)max6965, 1);  //TROUBLED LINE
Wire.requestFrom(max6965, (byte)1);  //TROUBLED LINE
What's going on is the compiler assumes "1" is an int. Functions taking two parameters often complain when you pass them one byte and one int rather than two bytes or two ints. The reason frequently is that there are (int, int) and (byte, byte) versions of the function, so the compiler doesn't know which one to use when you pass it one byte and one int.
And this way you save a whole byte of RAM because you keep your variable a byte! :smiley:
