Error/issue with verifiy/upload to Arduino
I am writing code to mine MacroKeyboard with a display and encoder. But I have a problem. Every single time I Klik on Verify or Upload, the "error" message displays "Compilation error: exit status 1" and in the OUTPUT window is a very "long text". I think that it is talking about libraries, but I think I have them alright.
Here is the "long text".
In file included from C:\Users\holom\Documents\Arduino\libraries\HID-Project\src/HID-Project.h:42:0,
from C:\Users\holom\Desktop\CODE MACRO KEYBOARD\sketch_dec18a\sketch_dec18a.ino:15:
C:\Users\holom\Documents\Arduino\libraries\HID-Project\src/MultiReport/ImprovedMouse.h:33:7: error: redefinition of 'class Mouse_'
class Mouse_ : public MouseAPI
In file included from C:\Users\holom\Desktop\CODE MACRO KEYBOARD\sketch_dec18a\sketch_dec18a.ino:10:0:
C:\Users\holom\Documents\Arduino\libraries\Mouse\src/Mouse.h:42:7: note: previous definition of 'class Mouse_'
class Mouse_
In file included from c:\users\holom\documents\arduino\libraries\hid-project\src\hid-apis\KeyboardAPI.h:29:0,
from c:\users\holom\documents\arduino\libraries\hid-project\src\hid-apis\defaultkeyboardapi.h:27,
from C:\Users\holom\Documents\Arduino\libraries\HID-Project\src/SingleReport/BootKeyboard.h:30,
from C:\Users\holom\Documents\Arduino\libraries\HID-Project\src/HID-Project.h:50,
c:\users\holom\documents\arduino\libraries\hid-project\src\keyboardlayouts\improvedkeylayouts.h:54:21: note: #pragma message: Using default ASCII layout for keyboard modules
#pragma message "Using default ASCII layout for keyboard modules"
In file included from C:\Users\holom\Desktop\CODE MACRO KEYBOARD\sketch_dec18a\sketch_dec18a.ino:8:0:
C:\Users\holom\Documents\Arduino\libraries\Keyboard\src/Keyboard.h:52:27: error: expected identifier before numeric constant
#define KEY_RETURN 0xB0
c:\users\holom\documents\arduino\libraries\hid-project\src\keyboardlayouts\improvedkeylayouts.h:103:5: note: in expansion of macro 'KEY_RETURN'
KEY_RETURN = 40, // Alias
C:\Users\holom\Documents\Arduino\libraries\Keyboard\src/Keyboard.h:52:27: error: expected '}' before numeric constant
C:\Users\holom\Documents\Arduino\libraries\Keyboard\src/Keyboard.h:52:27: error: expected unqualified-id before numeric constant
c:\users\holom\documents\arduino\libraries\hid-project\src\keyboardlayouts\improvedkeylayouts.h:521:1: error: expected declaration before '}' token
exit status 1
Please help i am lost :confused:
If someone can translate for me what that means i will be happy.
Welcome to the forum
Your topic was MOVED to its current forum category which is more appropriate than the original as it has nothing to do with Installation and Troubleshooting of the IDE
Please post your full sketch, using code tags when you do
Code for PADys(micropad) with execories - go watch a video about it → SOON WILL BE SOME
Made by → Jendys/Jendyx in 2022
email→ korky707@gmail.com
PS:Make sure you are using Arduino Pro micro 5V Atmega 32U4 board with build in 5V USB controler, it will be much more easy.
#include "Keyboard.h"               // keyboard(FX keys) library
#include <Keypad.h>                // This library is for interfacing with the Matrix
#include <Mouse.h>                // mouse move library
#include <SPI.h>                 // OLED
#include <Wire.h>               // OLED
#include <Adafruit_GFX.h>      // OLED
#include <Adafruit_SSD1306.h> // OLED
#include <HID-Project.h>     // encoder library
#include <SimpleDHT.h>     // include DHT
#define inputCLK 5   // Rotary Encoder Inputs on the board of the encoder
#define inputDT 6   // Rotary Encoder Inputs on the board of the encoder
#define inputSW 7  // Rotary Encoder Inputs on the board of the encoder
#define piezo 4 // PIEZO input pin 4
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1); //declaration for OLED
const byte ROWS = 3;  // 6 rows
const byte COLS = 6; // 4 columns
char keys[ROWS][COLS] = {
  {'Q', 'W', 'E', '7', '8', '9'},  // Matrix
  {'A', 'S', 'D', '4', '5', '6'},
  {'Y', 'X', 'C', '1', '2', '3'},  // these values need to be single character...
byte rowPins[ROWS] = {8, 9, 10, 16, 14, 15,};    //connect to the row pinouts of the keypad to arduino
byte colPins[COLS] = {18, 19, 20};   //connect to the column pinouts of the keypad to arduino
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void changeMode() {  // changing mode of the ENCODER
    mode = (mode % maxModes) + 1;
int currentStateCLK;
int previousStateCLK;
int modePushCounter = 0;        // counter for the number of button presses
int buttonState = 0;           // current state of the button
int latButtonState = 0;       // previous state of the button
int mouseMove;
int mode = 1;       // modes of the ENCODER
int maxModes = 4;  // modes of the ENCODER
const int ModeButton = 7;      // the pin that the Modebutton is attached to
const int pot = A1;            // pot for adjusting attract mode demoTime or mouseMouse pixel value
//const int Mode1= A2;
//const int Mode2= A3;         //Mode status LEDs
  Serial.begin(9600); // set serial being to 9600
  pinMode(piezo, OUTPUT);   // set piezo pin to output mode
  pinMode (inputCLK,INPUT);          // Set encoder pins as inputs
	pinMode (inputDT,INPUT);         // Set encoder pins as inputs
	pinMode(inputSW, INPUT_PULLUP); //Set encoder pins as input_pullup
  note(piezo, 261, 800); //C - play it
  noTone(piezo); // do not play
  note(piezo, 330, 800); //E
  noTone(piezo);
  note(piezo, 392, 800); //G
  noTone(piezo);
  note(piezo, 294, 800); //D
  noTone(piezo);
  note(piezo, 370, 800); //F#
  noTone(piezo);
  note(piezo, 440, 800); //A
  noTone(piezo);
  Consumer.begin();  // encoder
 	Keyboard.begin(); // encoder
  previousStateCLK = digitalRead(inputCLK); // Assign to previousStateCLK variable // Read the initial state of inputCLK
  if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3D)) { // Address 0x3D for 128x64 or 0x3C for 128x32
    Serial.println(F("SSD1306 allocation failed"));      // OLED
    for (;;); // Don't proceed, loop forever
  display.clearDisplay(); //display Text
  display.setTextSize(3);
  display.setTextColor(WHITE);
  display.setCursor(0,10);
  display.print("PADys");
  display.display();
  display.setTextSize(1);
  display.setCursor(0, 55);
  display.print("Macro PAD by Jendys");
  display.display();
  delay(2000);
  //ENCODER PART
	currentStateCLK = digitalRead(inputCLK);                 // Read the current state of inputCLK
	if (currentStateCLK != previousStateCLK){              // If the previous and the current state of the inputCLK are different then a pulse has occured
		if (digitalRead(inputDT) != currentStateCLK) {     // If the inputDT state is different than the inputCLK state then
			rotateRight();
		} else {                                         // the encoder is rotating counterclockwise
			rotateLeft();
	previousStateCLK = currentStateCLK;  // Update previousStateCLK with the current state
  if(!digitalRead(inputSW)) {        // changing mode and delay 300
    changeMode();
    delay(300);
void changeMode(){
void rotateLRight() {  // adding thinks to modes/case RIGHT ROTATE
  switch(mode) {
    case 1:
      // Increase the volume
      display.setTextSize(2);
      display.setCursor(0, 10);
      display.print("VOLUME +");
      Consumer.write(MEDIA_VOLUME_UP);
    case 2:
      // WEB - GOOGLE - Cltr + TAB
      display.print("Tabs ->");
      Keyboard.press(KEY_LEFT_CTRL);
      Keyboard.press(KEY_TAB);
      Keyboard.releaseAll();
    case 3:
      // Scroling
      display.print("Arrow Down");
      Keyboard.write(KEY_UP_ARROW);
    case 4:
      // Brush size
      display.print("Size +");
      Keyboard.press('[ ');
void rotateLeft() {     // adding thinks to modes/case LEFT ROTATE
  switch(mode) {
    case 1:
      // Decrease the volume
      display.print("VOLUME -");
      Consumer.write(MEDIA_VOLUME_DOWN);
    case 2:
      //Cltr + SHIFT + TAB
      display.setTextSize(2));
      display.print("Tabs <-");
      Keyboard.press(KEY_LEFT_SHIFT);
    case 3:
      // Scroling
      display.print("Arrow Up");
      Keyboard.press(KEY_DOWN_ARROW);
    case 4:
      // Brush size
      display.print("Size - ");
      Keyboard.press(']');
  // Keypad/MATRIX/Switches part
  char key = keypad.getKey();
  mouseMove = (analogRead(pot)); //reading the analog input, pot = pin A1
  mouseMove = map(mouseMove, 0,1023, 1,124); //remap the analog pot values fron 1 to 124
  checkModeButton();
    switch (modePushCounter) {                 // switch between keyboard configurations:
    case 0:                                   //Application Alpha or MODE 0. Example = Every button ends your Zoom call
       if (key) {
    Serial.println(key);
    switch (key) {
      case '1':
      KeyBoard.press(KEY_CONTROL);
      KeyBoard.press(KEY_NUM1);
      KeyBoard.releaseAll();
      case '2':
      KeyBoard.press(KEY_NUM2);
      case '3':
      KeyBoard.press(KEY_NUM3);
      case '4':
      case '5':
      case '6':
      case '7':
      case '8'
      case '9':
      case 'Q':
      case 'W':
      case 'E':
      case 'A':
      case 'S':
      case 'D':
      case 'Y':
      case 'X':
      case 'C':
     delay(100);
     Keyboard.releaseAll();  // this releases the buttons
This is the code it isn't done yet but I was thinking about trying some parts of the code bur it wast working please help me.
Similar Issue for me:
In file included from c:\users\joosl\documents\arduino\libraries\hid-project\src\hid-apis\KeyboardAPI.h:29:0,
from c:\users\joosl\documents\arduino\libraries\hid-project\src\hid-apis\defaultkeyboardapi.h:27,
from C:\Users\Joosl\Documents\Arduino\libraries\HID-Project\src/SingleReport/BootKeyboard.h:30,
from C:\Users\Joosl\Documents\Arduino\libraries\HID-Project\src/HID-Project.h:50,
from C:\Users\Joosl\Documents\Arduino\Projects\Macropad\Macropad.ino:4:
c:\users\joosl\documents\arduino\libraries\hid-project\src\keyboardlayouts\improvedkeylayouts.h:54:21: note: #pragma message: Using default ASCII layout for keyboard modules
c:\users\joosl\documents\arduino\libraries\hid-project\src\keyboardlayouts\improvedkeylayouts.h:73:25: error: expected identifier before '=' token
KEY_H = 11,
c:\users\joosl\documents\arduino\libraries\hid-project\src\keyboardlayouts\improvedkeylayouts.h:73:25: error: expected '}' before '=' token
c:\users\joosl\documents\arduino\libraries\hid-project\src\keyboardlayouts\improvedkeylayouts.h:73:25: error: expected unqualified-id before '=' token
c:\users\joosl\documents\arduino\libraries\hid-project\src\keyboardlayouts\improvedkeylayouts.h:521:1: error: expected declaration before '}' token
exit status 1
I checked the file from HID Project itself, but it was just a listing of the different characters. In this case, it was H, where it randomly expected something else than in every other line
And what does that mean :smiley:
I guess that dont solve oure problem
I guess that's right, I didn't want to create another topic that's so similar.
But, for me, i actually found a solution: I copied my code to the Arduino web ide, and tried to load it onto my Arduino from there. There aren't as many errors, and it loads onto the Arduino perfectly fine. Maybe it works out for you as well
If there are syntax errors in the code then it will not compile so will not upload to the Arduino
Oh nice i Will try it thx.
