Error Java
I tested IDE 1.0.3, 1.0.5 and 1.5.5 and i’ve the same error.
I tested with windows 7 pro and Windows XP Pro and always the same error.
It’s an error java.
Have you a solution for the message error :
Exception in thread “AWT-EventQueue-0” java.lang.OutOfMemoryError: Java heap space
at java.awt.image.DataBufferInt.(DataBufferInt.java:41)
at java.awt.image.Raster.createPackedRaster(Raster.java:458)
at java.awt.image.DirectColorModel.createCompatibleWritableRaster(DirectColorModel.java:1015)
at java.awt.GraphicsConfiguration.createCompatibleImage(GraphicsConfiguration.java:163)
at edu.mit.blocks.codeblockutil.GraphicsManager.getGCCompatibleImage(GraphicsManager.java:39)
at edu.mit.blocks.renderable.RenderableBlock.updateBuffImg(RenderableBlock.java:1378)
at edu.mit.blocks.renderable.RenderableBlock.(RenderableBlock.java:271)
at edu.mit.blocks.renderable.RenderableBlock.(RenderableBlock.java:186)
at edu.mit.blocks.renderable.FactoryRenderableBlock.(FactoryRenderableBlock.java:40)
at edu.mit.blocks.workspace.PageDrawerLoadingUtils.loadBlockDrawerSets(PageDrawerLoadingUtils.java:236)
at edu.mit.blocks.workspace.Workspace.loadWorkspaceFrom(Workspace.java:849)
at edu.mit.blocks.controller.WorkspaceController.loadFreshWorkspace(WorkspaceController.java:397)
at com.ardublock.core.Context.resetWorksapce(Context.java:105)
at com.ardublock.core.Context.(Context.java:71)
at com.ardublock.core.Context.getContext(Context.java:58)
at com.ardublock.ui.OpenblocksFrame.(OpenblocksFrame.java:69)
at com.ardublock.ui.ArduBlockToolFrame.(ArduBlockToolFrame.java:3)
at com.ardublock.ArduBlockTool.init(ArduBlockTool.java:29)
at processing.app.Editor.addTools(Editor.java:794)
at processing.app.Editor.buildToolsMenu(Editor.java:670)
at processing.app.Editor.buildMenuBar(Editor.java:476)
at processing.app.Editor.(Editor.java:205)
at processing.app.Base.handleOpen(Base.java:704)
at processing.app.Base.handleOpen(Base.java:669)
at processing.app.Base$6.actionPerformed(Base.java:1092)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1995)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2318)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242)
at javax.swing.AbstractButton.doClick(AbstractButton.java:357)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:1225)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:1266)
Thanks
hi, i have the same error as you as well, i think its the compiler
Sketch uses 1,116 bytes (3%) of program storage space. Maximum is 32,256 bytes.
Global variables use 11 bytes (0%) of dynamic memory, leaving 2,037 bytes for local variables. Maximum is 2,048 bytes.
processing.app.debug.RunnerException
    at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:129)
    at processing.app.Sketch.upload(Sketch.java:1672)
    at processing.app.Sketch.exportApplet(Sketch.java:1578)
    at processing.app.Sketch.exportApplet(Sketch.java:1550)
    at processing.app.Editor$DefaultExportHandler.run(Editor.java:2399)
    at java.lang.Thread.run(Thread.java:695)
Caused by: processing.app.debug.RunnerException: Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
    at cc.arduino.packages.Uploader.executeUploadCommand(Uploader.java:113)
    at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:127)
    ... 5 more
No Solution for this problem ?
