ERROR: Language client is not ready yet
A previous working setup with the IDE 2.2.1 now suddenly refuses to compile anything, not even the simplest "Blink"-example.
Error message in the IDE is "Compilation error: exit status 1".
Looking in the terminal window where I launched the IDE (with sudo) I see the following:
root ERROR Unexpected error when firing event on build did complete. "file:///private/tmp/arduino/sketches/7D5EF730081766D5D5CB148A0BD1036F" Error: Language client is not ready yet
    at LanguageClient.sendNotification (/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-arduino-tools/extension/dist/bundle.js:8932:19)
    at /Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-arduino-tools/extension/dist/bundle.js:179:28
    at /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-host.js:2:556773
    at t.CommandRegistryImpl.executeLocalCommand (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-host.js:2:557417)
    at t.CommandRegistryImpl.$executeCommand (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-host.js:2:556929)
    at /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-host.js:2:537919
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    at async c.handleRequest (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-host.js:2:114225)
Running the IDE on Mac (M1) with MacOS 14.1.2
I've restarted and also reinstalled the IDE but problem remains.
Thanks in advance!
/S.
UPDATE: Went back to IDE 1.8.19 with the exact same wiring and sketch and then everything worked flawlessly. Will probably stick with 1.x.x until 2.x.x works better.
