Error looking for help
im trying to use the bluetooth module hc 06 and every time y try to upload or verify my code this error mesage apeares
Arduino: 1.8.3 (Windows 10), Board: “Arduino Uno”
WARNING: Category ‘’ in library EEPROM is not valid. Setting to ‘Uncategorized’
WARNING: Category ‘’ in library SPI is not valid. Setting to ‘Uncategorized’
WARNING: Category ‘’ in library SoftwareSerial is not valid. Setting to ‘Uncategorized’
WARNING: Category ‘’ in library Wire is not valid. Setting to ‘Uncategorized’
Warning: platform.txt from core ‘Arduino AVR Boards’ contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} “{build.path}/{archive_file}” “{object_file}”, automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} “{archive_file_path}” “{object_file}”. Consider upgrading this core.
Sketch uses 2094 bytes (6%) of program storage space. Maximum is 32256 bytes.
Global variables use 185 bytes (9%) of dynamic memory, leaving 1863 bytes for local variables. Maximum is 2048 bytes.
java.io.IOException: Cannot run program “REMOVE/bin/avrdude”: CreateProcess error=2, The system cannot find the file specified
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
at processing.app.helpers.ProcessUtils.exec(ProcessUtils.java:26)
at cc.arduino.packages.Uploader.executeUploadCommand(Uploader.java:129)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:207)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:78)
at processing.app.SketchController.upload(SketchController.java:713)
at processing.app.SketchController.exportApplet(SketchController.java:686)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2149)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.io.IOException: CreateProcess error=2, The system cannot find the file specified
at java.lang.ProcessImpl.create(Native Method)
at java.lang.ProcessImpl.(ProcessImpl.java:386)
at java.lang.ProcessImpl.start(ProcessImpl.java:137)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
… 8 more
An error occurred while uploading the sketch
“Show verbose output during compilation”
option enabled in File → Preferences.
I think you'll probably need to post your sketch for someone to actually be able to see where the issue is. And you'll need to use code tags. More info on that is here, How To Use This Forum - Please Read
No need for the sketch here. Those are Java errors related to the IDE not the poster's code.
My first suggestion would be to remove and reinstall the IDE.
