error massage: expected primary-expression before '}' token
Hello there
I am making a sketch where i want to make the servo move randomly and als where i want to have te oppertunity to push a button so a LED goes on.
Somebody sayd i could made use of Millis, i tried to apply it to my sketch but i gives me this error massage: expected primary-expression before '}' token
If somebody knows how to help me it would be wonderfull! :slight_smile:
Thanks a lot.
int time;
unsigned long interval = 1000;
#include <Servo.h>
long randomNumber;
Servo myservo;
int pos = 0;
int buttonPin = 7;
int ledPin = 8;
boolean on = false;
int buttonstate = 0;
  myservo.attach(9);
  randomSeed(analogRead(0));
  pinMode(ledPin, OUTPUT);
  pinMode(buttonPin, INPUT);
  static unsigned long previousMillis = millis();
  if (millis() - previousMillis >= interval) {
    buttonstate = digitalRead(buttonPin);
    if (buttonstate == HIGH) {
      if (on == true) {
        on = false;
      }  else {
        on = true;
  if (on == true) {
    digitalWrite(ledPin, HIGH);
  else {
    digitalWrite(ledPin, LOW);
  previousMillis += interval;
    randomNumber = random(100000);
    Serial.print("random:");
    Serial.println(randomNumber);
    randomNumber = map(randomNumber, 0, 10000, 0, 180);
    Serial.print("servo:");
    myservo.write(randomNumber);
      for (pos = 0; pos <= 180; pos += 1)
      myservo.write(pos);
      for (pos = 180; pos >= 0; pos -= 1)
      myservo.write(pos);
Error Massage:
etc ...
What code do you want to execute if the interval has passed ?
Hello UKHeilBob,
I want to have the servo doing his random thing:
      myservo.write(pos);
      myservo.write(pos);
And the LED and Button doing there own thing, do i need to put the millis also on the LED and Button if i want to use the millis properly?
Thanks
You need to sort out your braces {}. They're in a mess e.g.
was never going to work. Any time you have close } followed by open{ with nothing between them something his gone wrong.
Steve
So put the code to be executed in braces
if (thisIsTrue)
  //execute the code between the braces
