Error Messaage
Hello,
So I am brand new to Arduino and programming in general. I am completing a capstone project that requires me to do this... I have getting an error when I try to compile my code. It reads:
C:\Users\Ashley Nelson\Documents\Arduino\EpiBand_Electronic_System_Code\EpiBand_Electronic_System_Code.ino:27:20: fatal error: TMRpcm.h: No such file or directory
I have no idea what a TMRpcm.h is... Is this my problem? How do I fix it?
Thank you in advance!
It means you didn't install that file. It's in the code for your capstone project, you should really understand what every line of your code for such an important project does.
It's difficult to provide any more help unless you give us more information:
  • It's obvious that you are using some code someone else wrote that you found somewhere. Post a link to where you found that code. Use the chain links icon on the toolbar to make the URL clickable when you post a link.
  • You didn't post the full error output so we're missing important information. When you encounter an error you'll see a button on the right side of the orange bar "Copy error messages". Click that button. Paste the error in a message here USING CODE TAGS (</> button on the toolbar).
/*Library by TMRh20 2012-2014
Contributors:
  ftp27 (GitHub) - setVolume(); function and code
  muessigb (GitHub) - metatata (ID3) support
#ifndef TMRpcm_h   // if x.h hasn't been included yet...
#define TMRpcm_h   //   #define this so the compiler knows it has been included
#include <Arduino.h>
#include <pcmConfig.h>
#include <pcmRF.h>
#if !defined (SDFAT)
	#include <SD.h>
#else
	#include <SdFat.h>
#endif
#if defined (ENABLE_RF)
	class RF24;
#endif
class TMRpcm
 public:
 	//TMRpcm();
 	//*** General Playback Functions and Vars ***
	void play(char* filename);
	void stopPlayback();
	void volume(char vol);
	void setVolume(char vol);
	void disable();
	void pause();
	void quality(boolean q);
	void loop(boolean set);
	byte speakerPin;
	boolean isPlaying();
    uint8_t CSPin;
	//*** Public vars used by RF library also ***
	boolean wavInfo(char* filename);
	boolean rfPlaying;
	unsigned int SAMPLE_RATE;
	//*** Advanced usage Vars ***
	byte listInfo(char* filename, char *tagData, byte infoNum);
	byte id3Info(char* filename, char *tagData, byte infoNum);
	byte getInfo(char* filename, char* tagData, byte infoNum);
	#if !defined (ENABLE_MULTI)//Normal Mode
		void play(char* filename, unsigned long seekPoint);
	//*** MULTI MODE **
	#else
		void quality(boolean q, boolean q2);
		void play(char* filename, boolean which);
		void play(char* filename, unsigned long seekPoint, boolean which);
		boolean isPlaying(boolean which);
		void stopPlayback(boolean which);
		void volume(char upDown,boolean which);
		void setVolume(char vol, boolean which);
		void loop(boolean set, boolean which);
	#endif
	#if defined (MODE2)
			byte speakerPin2;
	#endif
	//*** Recording WAV files ***
	void createWavTemplate(char* filename,unsigned int sampleRate);
	void finalizeWavTemplate(char* filename);
	#if defined (ENABLE_RECORDING)
		void startRecording(char* fileName, unsigned int SAMPLE_RATE, byte pin);
		void startRecording(char *fileName, unsigned int SAMPLE_RATE, byte pin, byte passThrough);
		void stopRecording(char *fileName);
	#endif
 private:
 	void setPin();
	void timerSt();
	unsigned long fPosition();
	unsigned int resolution;
	byte lastSpeakPin;
	byte metaInfo(boolean infoType, char* filename, char* tagData, byte whichInfo);
	boolean seek(unsigned long pos);
	boolean ifOpen();
		boolean searchMainTags(File xFile, char *datStr);
	#else
		unsigned long searchMainTags(SdFile xFile, char *datStr);
	#endif
	#if defined (ENABLE_MULTI)
		void ramp(boolean wBuff);
	#endif
	#if defined (MODE2)
		void setPins();
	#endif
#endif
Good luck.
-jim lee
