Here is the beginning of the code that should include line 41 either way
///Code written by Steve Heitman
///based off original code written by:
///Nick Devan - Touch screen navagation code https://code.google.com/p/reef-aquarium-controller/downloads/detail?name=New%20Life%20Reef%20Controller%20Gerber_Cam%20Files.zip&can=1&q=
///benjaf @ theplantedtank - Sunrise/Sunset code http://www.plantedtank.net/forums/showthread.php?t=213234
///NightattheOpera @ Nano-reef.com - Lunar Phase Code http://www.nano-reef.com/topic/217305-a-lunar-phase-function-for-the-arduino/
// Jarduino Aquarium Controller v.1.1 // http://www.ultimatereef.net/forums/member.php?u=44387 // http://www.reefcentral.co.uk/member.php/13262-TheDOdblG
//################# REVISION 7.0 - Updated 10/5/14
// THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
// IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
// FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
// AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
// LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
// OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
// THE SOFTWARE.
// You may modify and/or use it under the terms of the GNU General Public License as
// published by the Free Software Foundation version 3 of the License, or (at your option) any later
// version. However if you intend on using the program (either in its entirety or any
// part of it) in any way, shape, or form for PROFIT, you MUST contact me and obtain
// my EXPRESS WRITTEN CONSENT (contact information is provided above).
// VIOLATORS WILL BE PROSECUTED TO THE FULLEST EXTENT OF THE LAW.
//*******Included Libraries*******//
#include <UTouch.h>
#include <avr/pgmspace.h>
#include <UTFT.h>
#include <tinyFAT.h>
#include <UTFT_tinyFAT.h>
#include <EEPROM.h>
#include <RTClib.h>
#include <Wire.h>
#include <OneWire.h>
#include <DallasTemperature.h>
//******** Declare Touch/LCD/RTC **********
UTFT myGLCD(ITDB50, 38, 39, 40, 41); //sets LCD pins - change to your screen pin-out and aspect
UTouch myTouch(6, 5, 4, 3, 2,); //sets touch pins - change to your set up (default is usually 6,5,4,3,2)
UTFT_tinyFAT myFiles(&myGLCD);
RTC_DS1307 RTC;
//******** Call Fonts **********
extern uint8_t arial_bold[];
extern uint8_t Sinclair_S[];
extern uint8_t SevenSegmentFull[];
//******* Declare 1-Wire for TEMP sensors ********
#define ONE_WIRE_BUS 2 //sets sensor to pwm pin 2 - Change to your setup
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature tempsensors(&oneWire);
//DS18B20 sensor address' ******change these for your sensors*******
//link provided is a good sketch to get yours
//http://www.hacktronics.com/Tutorials/arduino-1-wire-address-finder.html
//I added this link because I found this to be a much easier sketch to use than the Dallas Multiple Example when
//trying to find Address'on a 1 wire bus.
DeviceAddress tankTemp = { 0x28, 0x09, 0xD3, 0x07, 0x04, 0x00, 0x00, 0x80 };
DeviceAddress sumpTemp = { 0x28, 0x48, 0x31, 0x2C, 0x04, 0x00, 0x00, 0x7F };
DeviceAddress rSinkTemp = {0x28, 0x00, 0x2D, 0x47, 0x04, 0x00, 0x00, 0xF2 };
DeviceAddress lSinkTemp = {0x28, 0x35, 0xF7, 0x2A, 0x04, 0x00, 0x00, 0x1A };
float TANK;
float SUMP;
float SINK1;
float SINK2;
//########################################### $Global Varibles #############################[#VAR]
//******************pH Variables*****************
float pH_read;
float pH_val;
//### Touch Screen Varibles ########################
int x, y;
//### Screen Select Pointers #######################
boolean home_screen = true;
boolean menu_screen = false;
boolean ledhome_screen = false;
boolean ledchannel_screen = false;
boolean ledevents_screen = false;
boolean clock_screen = false;
boolean tempgraph_screen = false;
boolean temphome_screen = false;
boolean ph_screen = false;
boolean settings_screen = false;
boolean outlet_screen = false;
boolean reminders_screen = false;
boolean weather_screen = false;
boolean timers_screen = false;
boolean calendar_screen = false;
boolean dosingato_screen = false;
boolean Enter_new_value = false;
boolean Enter_new_time = false;
boolean outlet_status = false;
boolean change_sunrise = false;
boolean change_moonmax = false;
boolean Enter_moon_value = false;
boolean feeding_popup = false;
boolean feedingtimer = false;
boolean showcountdown = false;
boolean feedingstatus = false;
boolean feedingcancel = false;
boolean pumpcalibration = false;
boolean Enter_new_dose = false;
boolean ledschedule = false;
boolean ledoff = false;
boolean lock_popup = false;
//### Clock Varibles ################################
int Hours, Minutes, Seconds;
int Day;
int Month;
int Year;
int Weekday;
String Current_time;
boolean Daytime = true;
boolean Was_day;
//####Outlet Variables #########################
int OUTLETS[8] = {A8, A9, A10, A11, A12, A13, A14, A15};
int outletState = 0;
///### LED Variables ############################
const int Wht_Ch1 = 6; //sets pwm pins for LED driver
const int RBlue_Ch1 = 7;
const int Blue_Ch1 = 8;
const int Wht_Ch2 = 9;
const int Blue_Ch2 = 11;
const int Wht_Ch3 = 12;
const int RBlue_Ch2 = 10;
const int UV_Ch1 = 13; // Pin 13 also being used for Moon Lighting
//change pins to your set-up if conflict
//#######Weather Strings###############
String Current_weather = "Sunny!"; //default strings...programs unfinished
String Coral_Accl = "off";
//### Led Varibles ##################################
int White_max = 0; //Dimming variables
int Blue_max = 0;
int RBlue_max = 0;
int UV_max = 0;
int change_max_bright = 0;
int Blue_Led_Brightness = 0; //Print LEDs % variables
int RBlue_Led_Brightness = 0;
int White_Led_Brightness = 0;
int UV_Led_Brightness = 0;
//### Led Schedule Varibles ##################################
int LEDmanual = 0;
int SunTwelve = 0;
int SunEight = 0;
int MoonStandard = 0;
int MoonReef = 0;
//EEPROM storage variables (address')
int whtsun = 0; //LEDs Max Bright
int rblsun = 1;
int blusun = 2;
int uvsun = 3;
int savesunhour = 4; //Sunrise Start time
int savesunmin = 5;
int savemoon = 6; //Moon Max Bright
int ledmanual = 7; //Sun Schedule Select
int suntwelve = 8;
int suneight = 9;
int moonstandard = 10; //Moon Schedule Select
int moonreef = 11;
[code]
but I don't see anywere there should be a ')'
