Hi all, I had Arduino IDE running on my netbook, but changed OS to Ubuntu. So I have reinstalled the Arduino IDE as per the instructions here - http://www.pluggy.me.uk/arduino-ubuntu/
Then I went through and reinstalled the libraries I was using, and finally tried to compile my (previously working) code.
It is not working. So I figured I would run some example code from each of the libraries to check each one works. So the first one is the MAX6675 library from http://ryanjmclaughlin.com/
When I run the example code from this I get the error message :- conflicting declaration 'int SCK' The rest of the error message is as follows:-
In file included from RBBB_PID_v1_1.cpp:4: /home/ross/Arduino/arduino-1.0/libraries/max6675/max6675.h:11:22: error: WProgram.h: No such file or directory In file included from RBBB_PID_v1_1.cpp:5: /home/ross/Arduino/arduino-1.0/libraries/MenuBackend/MenuBackend.h:195: error: stray ‘\342’ in program /home/ross/Arduino/arduino-1.0/libraries/MenuBackend/MenuBackend.h:195: error: stray ‘\200’ in program /home/ross/Arduino/arduino-1.0/libraries/MenuBackend/MenuBackend.h:195: error: stray ‘\250’ in program RBBB_PID_v1_1.cpp:6:20: error: PID_v1.h: No such file or directory In file included from RBBB_PID_v1_1.cpp:3: /home/ross/Arduino/arduino-1.0/libraries/LiquidCrystal_I2C/LiquidCrystal_I2C.h:80: error: conflicting return type specified for ‘virtual void LiquidCrystal_I2C::write(uint8_t)’ /home/ross/Arduino/arduino-1.0/hardware/arduino/cores/arduino/Print.h:48: error: overriding ‘virtual size_t Print::write(uint8_t)’ RBBB_PID_v1_1:10: error: conflicting declaration ‘int SCK’ /home/ross/Arduino/arduino-1.0/hardware/arduino/variants/standard/pins_arduino.h:43: error: ‘SCK’ has a previous declaration as ‘const uint8_t SCK’ RBBB_PID_v1_1:16: error: no matching function for call to ‘MAX6675::MAX6675(int&, int&, const uint8_t&, int&, float&)’ /home/ross/Arduino/arduino-1.0/libraries/max6675/max6675.h:16: note: candidates are: MAX6675::MAX6675(int, int, int, int) /home/ross/Arduino/arduino-1.0/libraries/max6675/max6675.h:14: note: MAX6675::MAX6675(const MAX6675&) RBBB_PID_v1_1:31: error: ‘PID’ does not name a type RBBB_PID_v1_1.cpp: In function ‘void setup()’: RBBB_PID_v1_1:148: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:150: error: ‘AUTOMATIC’ was not declared in this scope RBBB_PID_v1_1.cpp: In function ‘void loop()’: RBBB_PID_v1_1:172: error: no matching function for call to ‘MAX6675::read_temp(int)’ /home/ross/Arduino/arduino-1.0/libraries/max6675/max6675.h:17: note: candidates are: float MAX6675::read_temp() RBBB_PID_v1_1:184: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1.cpp: In function ‘void menuChanged(MenuChangeEvent)’: RBBB_PID_v1_1:223: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:237: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:250: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:334: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:340: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:346: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:352: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:358: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:364: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:370: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:376: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:382: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:387: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:394: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:401: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:408: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:415: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:422: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:429: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:436: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:443: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:450: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:457: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:465: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:473: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:480: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:487: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:494: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:501: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:508: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:515: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:522: error: ‘myPID’ was not declared in this scope RBBB_PID_v1_1:530: error: ‘myPID’ was not declared in this scope
Any suggestions?
