The problem is that count is defined in setup() but you try to use it in loop(). The problem comes from the C concept of scope. Search this site for posts about scope. Move the definition of count either into loop() or make it a global (i.e., defined just before setup()).
Also, please read the two posts by Nick Gammon at the top of this page. It has guidelines for posting here, especially on the use of code tags when posting source code. Also, before you post your code, while in the Arduino IDE, place the cursor in your code window and press Ctrl-T. It will reformat your code into a more common C style. Doing this before posting makes it easier to read your code.
Robin's idea of defining count within loop() using the static type qualifier is a good way to go. Doing so encapsulates (i.e., hides) the variable from other parts of the program and is much better than giving it global scope.
