Here is an error message which I don't understand. Can you assist?
Arduino: 1.8.3 (Windows 7), Board: "Arduino/Genuino Uno"
Sketch uses 2604 bytes (8%) of program storage space. Maximum is 32256 bytes.
Global variables use 237 bytes (11%) of dynamic memory, leaving 1811 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can't open device "\.\COM3": Access is denied.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
An error occurred while uploading the sketch
Exception in thread "Thread-105" java.util.ConcurrentModificationException
at java.util.LinkedList$LLSpliterator.forEachRemaining(LinkedList.java:1239)
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:481)
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:471)
at java.util.stream.ForEachOps$ForEachOp.evaluateSequential(ForEachOps.java:151)
at java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(ForEachOps.java:174)
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234)
at java.util.stream.ReferencePipeline.forEach(ReferencePipeline.java:418)
at cc.arduino.contributions.libraries.LibrariesIndexer.rescanLibraries(LibrariesIndexer.java:127)
at processing.app.BaseNoGui.onBoardOrPortChange(BaseNoGui.java:683)
at processing.app.Base.onBoardOrPortChange(Base.java:1297)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2179)
at java.lang.Thread.run(Thread.java:745)
option enabled in File -> Preferences.
