I am writing my first code for my Arduino robot. The compiler has thrown up this error message on line 20.
"error: a function-definition is not allowed here before '{' token
a function-definition is not allowed here before '{' token"
I believe my format is good and readable and I have counted all the brackets as suggested in other posts.
The code simply allows the robot to drive through a small square circuit or at least that's what I want it to do.
Best regards
Rob
#include <ArduinoRobot.h>
Robot.begin();
int head, new_head;
Robot.motorsWrite(100, 100); //Drive forward for one second
Robot.motorsWrite(0, 0); //stop
Robot.compassRead(); //Use compass to read current heading
head = Robot.compassRead(); //Assign value to head
new_head = head + 90; //define new heading
Robot.motorsWrite(50, -50); //start right turn
void loop() //use loop to monitor heading through turn
head = compassRead();
if (head < new_head) //nested loop stops turn when new heading achieved
delay(0);
You are trying to define another function called loop() in the middle of loop(). That is not allowed.
The code has "int head, new_head" outside any functions. It is not in setup(), and it is not in loop(), nor any other function. It will not work there as I understand it.
Thanks Delta_G for the info.
I had thought that could only be done before the setup().
Then, using the 2 pass compiler, I guess you could even do that way at the bottom of the script. Good info.
