Error Message: Error Compiling for Arduino Uno
To whomever it may concern/those who might be able to offer some assistance:
I have this code written up and I’m having some trouble in getting my code to run as I’m now getting an error message I’ve not received before,
"Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
Tone.cpp.o (symbol from plugin): In function `timer0_pin_port':
(.text+0x0): multiple definition of `__vector_7'
libraries\IRremote\IRremote.cpp.o (symbol from plugin):(.text+0x0): first defined here
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Uno. "
I think that it relates to my use of the translate function directly underneath the void loop() I’m using for allowing my remote to input conditions for the outputs I want from my Uno board (provided a comment next to it as well in-code).
Any help or clarification would be a huge help!
Thank you in advance.
//////////////////////////IR RECIEVER CODE INITIALIZATION////////////////////////
#include <IRremote.h>
#include <IRremoteInt.h>
#include "IRremote.h"
#include<Servo.h>
Servo RIGHTservo;
int receiver = 2; // Signal Pin of IR receiver to Arduino Digital Pin 2
/*-----( Declare objects )-----*/
IRrecv irrecv(receiver);     // create instance of 'irrecv'
decode_results results;      // create instance of 'decode_results'
//////////////////////END OF IR RECIEVER CODE INITIALIZATION//////////////////////
//////////////////////// START OF SONG INITIALIZATION ////////////////////////
#define NOTE_B0  31
#define NOTE_C1  33
#define NOTE_CS1 35
#define NOTE_D1  37
#define NOTE_DS1 39
#define NOTE_E1  41
#define NOTE_F1  44
#define NOTE_FS1 46
#define NOTE_G1  49
#define NOTE_GS1 52
#define NOTE_A1  55
#define NOTE_AS1 58
#define NOTE_B1  62
#define NOTE_C2  65
#define NOTE_CS2 69
#define NOTE_D2  73
#define NOTE_DS2 78
#define NOTE_E2  82
#define NOTE_F2  87
#define NOTE_FS2 93
#define NOTE_G2  98
#define NOTE_GS2 104
#define NOTE_A2  110
#define NOTE_AS2 117
#define NOTE_B2  123
#define NOTE_C3  131
#define NOTE_CS3 139
#define NOTE_D3  147
#define NOTE_DS3 156
#define NOTE_E3  165
#define NOTE_F3  175
#define NOTE_FS3 185
#define NOTE_G3  196
#define NOTE_GS3 208
#define NOTE_A3  220
#define NOTE_AS3 233
#define NOTE_B3  247
#define NOTE_C4  262
#define NOTE_CS4 277
#define NOTE_D4  294
#define NOTE_DS4 311
#define NOTE_E4  330
#define NOTE_F4  349
#define NOTE_FS4 370
#define NOTE_G4  392
#define NOTE_GS4 415
#define NOTE_A4  440
#define NOTE_AS4 466
#define NOTE_B4  494
#define NOTE_C5  523
#define NOTE_CS5 554
#define NOTE_D5  587
#define NOTE_DS5 622
#define NOTE_E5  659
#define NOTE_F5  698
#define NOTE_FS5 740
#define NOTE_G5  784
#define NOTE_GS5 831
#define NOTE_A5  880
#define NOTE_AS5 932
#define NOTE_B5  988
#define NOTE_C6  1047
#define NOTE_CS6 1109
#define NOTE_D6  1175
#define NOTE_DS6 1245
#define NOTE_E6  1319
#define NOTE_F6  1397
#define NOTE_FS6 1480
#define NOTE_G6  1568
#define NOTE_GS6 1661
#define NOTE_A6  1760
#define NOTE_AS6 1865
#define NOTE_B6  1976
#define NOTE_C7  2093
#define NOTE_CS7 2217
#define NOTE_D7  2349
#define NOTE_DS7 2489
#define NOTE_E7  2637
#define NOTE_F7  2794
#define NOTE_FS7 2960
#define NOTE_G7  3136
#define NOTE_GS7 3322
#define NOTE_A7  3520
#define NOTE_AS7 3729
#define NOTE_B7  3951
#define NOTE_C8  4186
#define NOTE_CS8 4435
#define NOTE_D8  4699
#define NOTE_DS8 4978
#define REST      0
// change this to make the song slower or faster
int tempo = 160;
// change this to whichever pin you want to use
int buzzer = 11;
#define delayTime 10 // fading time between colors
// notes of the moledy followed by the duration.
// a 4 means a quarter note, 8 an eighteenth , 16 sixteenth, so on
// !!negative numbers are used to represent dotted notes,
// so -4 means a dotted quarter note, that is, a quarter plus an eighteenth!!
int melody[] = {
  // Keyboard cat
  // Score available at https://musescore.com/user/142788/scores/147371
  REST, 1,
  REST, 1,
  NOTE_C4, 4, NOTE_E4, 4, NOTE_G4, 4, NOTE_E4, 4,
  NOTE_C4, 4, NOTE_E4, 8, NOTE_G4, -4, NOTE_E4, 4,
  NOTE_A3, 4, NOTE_C4, 4, NOTE_E4, 4, NOTE_C4, 4,
  NOTE_A3, 4, NOTE_C4, 8, NOTE_E4, -4, NOTE_C4, 4,
  NOTE_G3, 4, NOTE_B3, 4, NOTE_D4, 4, NOTE_B3, 4,
  NOTE_G3, 4, NOTE_B3, 8, NOTE_D4, -4, NOTE_B3, 4,
  NOTE_G3, 4, NOTE_G3, 8, NOTE_G3, -4, NOTE_G3, 8, NOTE_G3, 4,
  NOTE_G3, 4, NOTE_G3, 4, NOTE_G3, 8, NOTE_G3, 4,
  NOTE_G3, -1,
// sizeof gives the number of bytes, each int value is composed of two bytes (16 bits)
// there are two values per note (pitch and duration), so for each note there are four bytes
int notes = sizeof(melody) / sizeof(melody[0]) / 2;
// this calculates the duration of a whole note in ms
int wholenote = (40000 * 4) / tempo;
int divider = 0, noteDuration = 0;
/////////////////////// END OF SONG INITIALIZATION ///////////////////////
//////////////////////START LED DISPLAY 1: NO FADE INITIALIZATION///////////////////////
#define BLUE 3
#define GREEN 5
#define RED 6
////////////////////// END LED DISPLAY 2:FADE INITIALIZATION///////////////////////
// define variables
int redValue;
int greenValue;
int blueValue;
int red_inc;
int green_inc;
int blue_inc;
int motor_speed;
int song_play;
 //function translate IR
int translateIR() // takes action based on IR code received
// describing Remote IR codes
  switch (results.value)
    case 0xFF6897:
      Serial.println("0");   break;
    case 0xFF30CF: Serial.println("1");    break;
    case 0xFF18E7: Serial.println("2");    break;
    case 0xFF7A85: Serial.println("3");    break;
    case 0xFF10EF: Serial.println("4");    break;
    default:
      Serial.println(" other button : ");
      Serial.println(results.value);
  }// End Case
  delay(500); // Do not get immediate repeat
} //END translateIR
  //////////////////////START LED DISPLAY 1:NO FADE SETUP///////////////////////
  pinMode(RED, OUTPUT);
  pinMode(GREEN, OUTPUT);
  pinMode(BLUE, OUTPUT);
  digitalWrite(RED, HIGH);
  digitalWrite(GREEN, LOW);
  digitalWrite(BLUE, LOW);
  RIGHTservo.attach(12);//Attach the right servo to the Servo Pin 12
  Serial.println("IR Receiver Button Decode");
  irrecv.enableIRIn(); // Start the receiver
  //////////////////////END OF IR SET UP////////////////////
  //////////////////////BEGINNING OF SONG CODE SET UP ////////////////////
  // iterate over the notes of the melody.
  // Remember, the array is twice the number of notes (notes + durations)
  for (int thisNote = 0; thisNote < notes * 2; thisNote = thisNote + 2) {
    // calculates the duration of each note
    divider = melody[thisNote + 1];
    if (divider > 0) {
      // regular note, just proceed
      noteDuration = (wholenote) / divider;
    } else if (divider < 0) {
      // dotted notes are represented with negative durations!!
      noteDuration = (wholenote) / abs(divider);
      noteDuration *= 1.5; // increases the duration in half for dotted notes
    // we only play the note for 90% of the duration, leaving 10% as a pause
    tone(buzzer, melody[thisNote], noteDuration * 0.9);
    // Wait for the specief duration before playing the next note.
    delay(noteDuration);
    // stop the waveform generation before the next note.
    noTone(buzzer);
  }////////////////////// END OF SONG CODE SET UP////////////////////
}//end of setup
  //////////////////////IR CODE LOOP START//////////////////////
//for int translateIR()  //**I PUT THIS HERE AS A SUGGESTION BUT WHEN RUNNING IT, IT STATES AN INITIALIZATION ERROR SO I COMMENTED IT OUT**
  if (irrecv.decode(&results)) { // have we received an IR signal?
    switch (results.value) {
      case 0xFF6897:
        redValue = 1; // choose a value between 1 and 255 to change the color.
        greenValue = 1;
        blueValue = 1;
        red_inc = 1;
        green_inc = 0;
        blue_inc = 0;
      case 0xFF30CF:
        greenValue = 1;
        blueValue = 1;
        red_inc = 0;
        green_inc = 1;
        blue_inc = 0;
      case 0xFF18E7:
        greenValue = 1;
        blueValue = 1;
        red_inc = 0;
        green_inc = 0;
        blue_inc = 1;
      case 0xFF7A85:
        motor_speed = 1400;
        greenValue = 1;
        blueValue = 1;
        red_inc = 0;
        green_inc = 1;
        blue_inc = 0;
      case 0xFF10EF:
        song_play = 1;
    }// End Case
    irrecv.resume(); // receive the next value
  }//end button press
  //what happens always wo button press-------------------
  //check and change red value
  //basic unit-----------------------
  if (255 > redValue + red_inc) {
    redValue = redValue + red_inc;
  else {
    redValue = 1;
    blueValue = 50;
  //end basic unit repeat for all colors--------
//blue call out
  if (255 > blueValue + blue_inc) {
    blueValue = blueValue + blue_inc;
  else {
    blueValue = 1;
    greenValue = 50;
  // green call out
 if (255 > greenValue + green_inc) {
    greenValue = greenValue + green_inc;
  else {
    greenValue = 1;
    redValue = 50;
  //send all values to the leds
  analogWrite(RED, redValue);
  analogWrite(GREEN, greenValue);
  analogWrite(BLUE, blueValue);
  //tell motor to spin
  RIGHTservo.write(motor_speed);
  delay(delayTime);
  if (song_play == 1) {
    //code to trigger the song play
      if (divider > 0) {
      noTone(buzzer);
    } //for loop for song
    song_play = 0; // no mas song after you play the song
  }// end song play
} //end loop--------------------------------------------
(Code tags added by Moderator)
Both the Tone and the IRremote libraries are using timer1. The timer can’t be shared. I do not know of alternative libraries.
I figured it out. Actually, I had needed to delete and redownload my IR remote code files which were the source of error somehow.
The IRremote library was recently updated. Older code (prior to version 3.x) will not work with the new library.
@jfuchs4, your topic was moved to a more suitable section on the forum.
