Error Message "expected primary-expression"
I am trying to write the code for a machine that will shut my lights off when I push the "FUNC/STOP" button on the remote. I get the error message "expected primary-expression before 'irrecv'". Here is my code.
#include "IRremote.h"
#include "Servo.h"
const int servoPin = 11;
int pos = 0;
Servo servo1;
IRrecv irrecv(receiver);
decode_results results;
Here is my code.
Did you forget to post most of it ?
You need to post all the code, all you have shown us is a few lines at the top of the program.
I am not completely finished writing it yet but here is what I have so far.
#include "Servo.h"
int pos = 0;
Servo servo1
void translateIR() {
  switch(results.value){
    case 0xFFE21D: Serial.println("FUNC/STOP"); break;
  default:
    Serial.print(" That Didn't Work!!!  ");
    Serial.println(results.value);
void setup(){
  Serial.println("IR Receiver Button Decode");
  irrecv.enableIRIn();
  pinMode(9, INPUT);
  pinMode(11, OUTPUT);
  servo1.attach(11);
void loop(){
Servo servo1
Something missing, perhaps ?
@UKHeliBob, it should be "Servo servo1;". Sorry, is that what your talking about?
Yes
However, it is not the only error.
What is receiver ?
Well, its easy to check for yourself.
If you do a Google serace on;
'arduino servo reference'
You will be directed to a reference page with links to examples of how to use the Servo command.
Ok. But what about the error message "expected primary-expression before 'irrecv'"? It is talking about the line that says "IRrecv irrecv(receiver);"
#include "Servo.h"
int pos = 0;
Servo servo1
  default:
void setup(){
  pinMode(9, INPUT);
  servo1.attach(11);
void loop(){
Have you fixed the problem with the Servo object ?
Yes but it now says "'receiver' was not declared in this scope". It is still talking about the same line.
No
Where is receiver declared ?
What do you mean?
Your code has this in it
What is receiver and how does the program know what it is and where to find it ?
