Error message for fsm for line following robot using dijkstra algorithm any help would be appreciated thank you
I am making a robot ,and I am also fairly new to arduino,that finds the most optimal path in a maze this is the simple fsm that is just for testing the robot I have no idea whats wrong with the code.
i get this error meassage
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Arduino Uno"
pooy_motor_3:21:14: error: expected unqualified-id before ')' token
void forward(){
pooy_motor_3:28:11: error: expected unqualified-id before ')' token
void left(){
pooy_motor_3:35:12: error: expected unqualified-id before ')' token
void right(){
C:\Users\User\OneDrive\year 2\rob\pooy_motor_3\pooy_motor_3.ino: In function 'void setup()':
pooy_motor_3:42:6: error: redefinition of 'void setup()'
C:\Users\User\OneDrive\year 2\rob\pooy_motor_3\pooy_motor_3.ino:12:6: note: 'void setup()' previously defined here
C:\Users\User\OneDrive\year 2\rob\pooy_motor_3\pooy_motor_3.ino: In function 'void loop()':
pooy_motor_3:53:11: error: expected primary-expression before ')' token
forward();
pooy_motor_3:59:8: error: expected primary-expression before ')' token
left();
pooy_motor_3:65:9: error: expected primary-expression before ')' token
right();
pooy_motor_3:71:11: error: expected primary-expression before ')' token
reverse();
exit status 1
option enabled in File -> Preferences.
#define forward
int fO;
#define left
int lE;
#define right
int rI;
#define reverse
int rE;
//void reverse();
  // Pins 8 and 9 are used to set the direction, set one high and one low for one direction and swap them for the other direction.
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  // Pin 10 is used to set the power by using PWM on the enable pin
  pinMode(10, OUTPUT);
void forward(){
  digitalWrite(7, HIGH);
  digitalWrite(8, LOW);
  digitalWrite(9, HIGH);
  digitalWrite(10, LOW);
void left(){
  digitalWrite(9, LOW);
  digitalWrite(10, HIGH);
void right(){
  digitalWrite(7, LOW);
  digitalWrite(8, HIGH);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
 // one output pin for each of the motors
 // 7 and 8 are the left and 9 10 are the right
  forward();
  left();
  right();
  reverse();
Get rid of this:
#define forward
and the other defines.
oh really? is that all
and thank you:)
