I am trying a garage door opener project I got off of Instructables; noob here, btw.
When I try to verify my code I get an error.
Here is the code (it's not that long) with the error message following it:
** Password manager checks and updates passwords in the eeprom.
** Passwords are stored in fixed size records and are checked directly against the value read
** from the eeprom.
#pragma once
#include <Arduino.h>
class CPasswordManager
// Base address for storing passwords in the eeprom.
const unsigned c_uBaseAddress;
// Size of each password, including a null terminator.
const unsigned c_uPasswordLength;
// Limit on the number of passwords stored.
const unsigned c_uMaxPasswords;
// If the user has recently supplied a valid password, they
// can activate the door again without supplying a new password
// for a short time.
uint32_t m_uLastValidPasswordTime; // millis timer when last password was received
bool m_bValidPasswordRecently; // True if we had a valid password recently (the grace period hasn't expired).
enum EConstants
PASSWORD_GRACE_PERIOD = 5 * 60 * 1000 // [ms]
public:
CPasswordManager(unsigned uBaseAddress, unsigned uPasswordLength, unsigned uMaxPasswords);
void InitializePasswordStore();
bool IsPasswordValid(const char *pchTest, bool bCaseSensitive);
void ListPasswords();
void SetPassword(int nPassword, const char *pchNewPassword);
void ClearPassword(int nPassword);
bool HasValidPassword();
void CheckGracePeriod();
void ClearGracePassword();
extern CPasswordManager PasswordManager;
HERE IS THE ERROR MESSAGE
In file included from sketch\CommandProcessing.cpp:2:0:
sketch\PasswordManager.h:29:38: warning: integer overflow in expression [-Woverflow]
PasswordManager.h:29: error: overflow in constant expression [-fpermissive]
PasswordManager.h:29: error: enumerator value for 'PASSWORD_GRACE_PERIOD' is not an integer constant
exit status 1
