Error Message Help
Can anyone explain this error message to me? Ive been trying to solve it for days but it still appears.
pi@raspberrypi:~/eyeLock/alexa-avs-sample-app/samples/companionService $ npm start
(node:3700) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
alexa-voice-service-sample-companion-service@1.0.0 start /home/pi/eyeLock/alexa-avs-sample-app/samples/companionService
node ./bin/www
This node service needs to be running to store token information memory and vend them for the AVS app.
fs.js:646
return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
Error: ENOENT: no such file or directory, open ‘’
at Object.fs.openSync (fs.js:646:18)
at Object.fs.readFileSync (fs.js:551:33)
at Object. (/home/pi/eyeLock/alexa-avs-sample-app/samples/companionService/bin/www:21:13)
at Module._compile (module.js:652:30)
at Object.Module._extensions…js (module.js:663:10)
at Module.load (module.js:565:32)
at tryModuleLoad (module.js:505:12)
at Function.Module._load (module.js:497:3)
at Function.Module.runMain (module.js:693:10)
at startup (bootstrap_node.js:188:16)
npm ERR! alexa-voice-service-sample-companion-service@1.0.0 start: node ./bin/www
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the alexa-voice-service-sample-companion-service@1.0.0 start script.
npm ERR! This is most likely a problem with the alexa-voice-service-sample-companion-service package,
npm ERR! not with npm itself.
npm ERR! Tell the author that this fails on your system:
npm ERR! node ./bin/www
npm ERR! You can get their info via:
npm ERR! npm owner ls alexa-voice-service-sample-companion-service
npm ERR! There is likely additional logging output above.
npm ERR! System Linux 4.14.98-v7+
npm ERR! command “/usr/bin/node” “/usr/bin/npm” “start”
npm ERR! cwd /home/pi/eyeLock/alexa-avs-sample-app/samples/companionService
npm ERR! node -v v8.11.1
npm ERR! npm -v 1.4.21
npm ERR! code ELIFECYCLE
npm WARN This failure might be due to the use of legacy binary “node”
npm WARN For further explanations, please read
/usr/share/doc/nodejs/README.Debian
npm ERR!
npm ERR! Additional logging details can be found in:
npm ERR! /home/pi/eyeLock/alexa-avs-sample-app/samples/companionService/npm-debug.log
npm ERR! not ok code 0
Not an Arduino error.
Leticiar:
You'll have much better chance of success on a RPi forum.
yea I posted it in a RPi forum and no one has answered
Try searching on the error message - I found several postings on various forums - that message seems to be going around
