Error message i do not understand
Hello Arduwizards
I have the following error problem:
i_pomba.ino: In function 'void setup()':
i_pomba:76: error: 'key1' was not declared in this scope
i_pomba:78: error: expected `;' before 'max_darm'
with the code in void():
 #include <Keypad.h>
#include <LiquidCrystal.h>
#include <Tone.h>
#define pound 14
Tone tone1;
int max_arm;
int max_darm;
int Scount;
int Mcount;
int DefuseTimer=0;
long scMillis=0;
long interval=1000;
char pass[4];
int currentLength=0;
int i=0;
char entered[4];
int ledPin=2;
int ledPin2=3;
LiquidCrystal lcd(7,8,10,11,12,13);
const byte ROWS=4;
const byte COLS=3;
char keys[ROWS][COLS]={
   {'1','2','3'},
   {'4','5','6'},
   {'7','8','9'},
   {'*','0','#'}
byte rowPins[ROWS]={5,A5,A4,A2};
byte colPins[COLS]={A1,A0,A3};
Keypad keypad=Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
void setup(){
  pinMode(ledPin, OUTPUT);
  pinMode(ledPin2, OUTPUT);
  tone1.begin(9);
  lcd.begin(16,2);
  lcd.clear();
  lcd.setCursor(0,0);
  //Give me the arm time
  max_arm=1;
  do
    lcd.print("Arm Time: ");
    lcd.print(max_arm);
    lcd.print("min");
    char key1=keypad.getKey();
    lcd.cursor();
    key1 == NO_KEY;
    if(key1!=NO_KEY)
      if(key1=='2')
      max_arm++;
      if(key1=='8')
      max_arm--;
    lcd.clear();
    lcd.setCursor(0,0);
  }while(key1 != '5')
  //Give the dissarm time
   max_darm=1;
What i'm trying to do is to make the user give me a time of arming the bomb using the keypad numbers 2 and 8 as UP and DOWN and the keypads 5 as OK
I can't immediately see what is wrong but I did spot this :
   key1 == NO_KEY;
    if(key1!=NO_KEY)
In the first line I assume that == should be = so that key1 is set to NO_KEY but if that is the case then in the second line how likely is it that key1 will not equal NO_KEY ?
By the way, the line numbers in the error messages do not match the line numbers in the code posted so have you posted the correct version of the program ?
EDIT : Now I notice that you have not posted all of the program anyway so maybe the answer is in the missing lines
As you only posted 67 lines of code it is hard to help you.
My guess is that, because key1 was defined as a local variable in line 53 it is not visible to the code at line 76 (which is not visible to me either).
Simple solution may be to make key1 a global variable.
...R
indeed i did some corrections while posting....
i declared the key1 and key3 as global vars and solved the error that gave me but i have run to some others as well :cry: it's my first ardu program so please bear with me....
the errors
enabled in File > Preferences.
Arduino: 1.0.6 (Windows NT (unknown)), Board: "Arduino Uno"
i_pomba:19: error: variable or field 'timer1' declared void
i_pomba:19: error: 'max_arm' was not declared in this scope
i_pomba.ino: In function 'void loop()':
i_pomba:135: error: 'timer1' was not declared in this scope
i_pomba.ino: At global scope:
i_pomba:138: error: variable or field 'timer1' declared void
Aaaaand the whole code so far:
Defusable Paintball Bomb:
Made by Vangelis Moutafis
Keypad lay out:
1  2  3
4  5  6
7  8  9
*  0  #
#include <Keypad.h>
#include <Tone.h>
#define pound 14
Tone tone1;
int max_arm;//hronos arm
int max_darm;//hronos disarm
int Scount=0;
char key1;
char key3;
long scMillis=0;//apo8ikefsi telefteou hronou gia 2i pros8esi
long interval=1000;//gia lepta
char pass[4];
int currentLength=0;//poios apo tous ari8mus grafetai
int i=0;
char entered[4];
int ledPin=2;//Yellow led
int ledPin2=3;//Red led
LiquidCrystal lcd(7,8,10,11,12,13);// pins tis lcd
//Gia to keypad
const byte ROWS=4;
const byte COLS=3;
   {'1','2','3'},
   {'4','5','6'},
   {'7','8','9'},
   {'*','0','#'}
byte rowPins[ROWS]={5,A5,A4,A2};//ta pins pou en gia tis grammes
byte colPins[COLS]={A1,A0,A3};//ta pins pou en gia tis stiles
void setup(){
  pinMode(ledPin, OUTPUT);//kamei to pin 2 san output
  pinMode(ledPin2, OUTPUT);//kamei to pin 3 san output
  tone1.begin(9);
  lcd.begin(16,2);//16x2 haraktires lcd
  Serial.begin(9600);//tahitia metadwsis meta3i arduinu j lcd
  lcd.clear();
  lcd.setCursor(0,0);
  //Posos enna o hronos gia na tin kamun arm
  max_arm=1;
  do
    lcd.print(max_arm);
    lcd.print("min");
    lcd.cursor();
    key1 == NO_KEY;
    if(key1!=NO_KEY)
      if(key1=='2')
      max_arm++;
      if(key1=='8')
      max_arm--;
    lcd.clear();
    lcd.setCursor(0,0);
  }while(key1 != '5');
  //Posos hronos gia disarm:
   max_darm=1;
  do
    lcd.print("Dsrm Time: ");
    lcd.print(max_darm);
    lcd.print("min");
    key3=keypad.getKey();
    lcd.cursor();
    key3==NO_KEY;
    if(key3!=NO_KEY)
      if(key3=='2')
      max_darm++;
      if(key3=='8')
      max_darm--;
    lcd.clear();
    lcd.setCursor(0,0);
  }while(key3!='5');
  //Gia na men kamume kamia malakia me ton kwdiko chakarw an t evalame swsta
 lcd.print("Enter Code: ");
  while (currentLength <4)
    lcd.setCursor(currentLength +6,1);
    lcd.cursor();
    char key=keypad.getKey();
    key==NO_KEY;
    if (key!=NO_KEY)
      if ((key!='*')&&(key!='#'))
        lcd.print(key);
        currentLength++;
        tone1.play(NOTE_C6,200);
  if (currentLength == 4)
    lcd.noCursor();
    lcd.home();
    lcd.print("You've Entered: ");
    lcd.setCursor(6,1);
    lcd.print(pass[0]);
    lcd.print(pass[1]);
    lcd.print(pass[2]);
    lcd.print(pass[3]);
    tone1.play(NOTE_E6,200);
    delay(3000);
    lcd.clear();
    currentLength=0;
void loop(){
  timer1(max_arm);
void timer1(max_arm)
  int Scount=0;
  Serial.print(max_arm);
  if(max_arm<0)
    lcd.noCursor();
    lcd.Clear();
    lcd.home();
    lcd.print("BOOOOOOOOOM!!!!");
    lcd.setCursor(0,1);
    lcd.print("Bomb exploded");
    while(max_arm)
      digitalWrite(ledPin, HIGH); // sets the LED on
      tone1.play(NOTE_A2, 90);
      delay(100);
      digitalWrite(ledPin, LOW); // sets the LED off
      delay(100);
      digitalWrite(ledPin2, HIGH); // sets the LED on
      delay(100);
      digitalWrite(ledPin2, LOW); // sets the LED off
      delay(100);
  lcd.setCursor(0,1);//2i grammi
  lcd.print("Timer:");
  if (max_arm >= 10)
      lcd.setCursor (10,1);
      lcd.print (Max_arm);
  if (max_arm < 10)
      lcd.setCursor (7,1);
      lcd.write ("0");
      lcd.setCursor (8,1);
      lcd.print(max_arm);
  lcd.print (":");
  if (Scount >= 10)
      lcd.print (Scount);
  if (Scount < 10)
      lcd.write ("0");
      lcd.setCursor (11,1);
      lcd.print (Scount);
     if (Scount <1) // if 60 do this operation
      max_arm--; // - 1 sta lepta
      Scount = 59; // reset Scount
  if (Scount > 0) // do this oper. 59 times
      if(currentMillis - secMillis > interval)
          tone1.play(NOTE_G5, 200);
          secMillis = currentMillis;
          Scount --; // add 1 to Scount
          delay(10); // waits for a second
          //lcd.clear();
    if(max_arm==2)
      digitalWrite(letPin2,HIGH);
    if(max_arm==1){
      digitalWrite(ledPin,HIGH);
      digitalWrite(ledPin2,LOW);
sorry i uploded with greek comments i will upload with english
Keypad lay out:
1  2  3
4  5  6
7  8  9
*  0  #
#include <Keypad.h>
#include <Tone.h>
#define pound 14
Tone tone1;
int max_arm;//Time to arm
int max_darm;//Time to disarm
int Scount=0;
char key1;
char key3;
long scMillis=0;
long interval=1000;
char pass[4];
int i=0;
char entered[4];
int ledPin=2;//yellow led
LiquidCrystal lcd(7,8,10,11,12,13);// pins of lcd
//For keypad
const byte ROWS=4;
const byte COLS=3;
   {'1','2','3'},
   {'4','5','6'},
   {'7','8','9'},
   {'*','0','#'}
byte rowPins[ROWS]={5,A5,A4,A2};//pins for rows
byte colPins[COLS]={A1,A0,A3};//pins for colums
void setup(){
  tone1.begin(9);
  lcd.begin(16,2);//16x2 lcd
  lcd.clear();
  lcd.setCursor(0,0);
  //give time to arm
  max_arm=1;
  do
    lcd.print(max_arm);
    lcd.print("min");
    lcd.cursor();
    key1 == NO_KEY;
    if(key1!=NO_KEY)
      if(key1=='2')
      max_arm++;
      if(key1=='8')
      max_arm--;
    lcd.clear();
    lcd.setCursor(0,0);
  //Give time to dissarm
   max_darm=1;
  do
    lcd.print("min");
    lcd.cursor();
    key3==NO_KEY;
    if(key3!=NO_KEY)
      if(key3=='2')
      max_darm++;
      if(key3=='8')
      max_darm--;
    lcd.clear();
    lcd.setCursor(0,0);
  }while(key3!='5');
  //Give code
    lcd.cursor();
    key==NO_KEY;
    if (key!=NO_KEY)
        lcd.print(key);
        currentLength++;
    lcd.noCursor();
    lcd.home();
    lcd.setCursor(6,1);
    lcd.print(pass[0]);
    lcd.print(pass[1]);
    lcd.print(pass[2]);
    lcd.print(pass[3]);
    delay(3000);
    lcd.clear();
    currentLength=0;
void loop(){
  timer1(max_arm);
  int Scount=0;
  if(max_arm<0)
    lcd.noCursor();
    lcd.Clear();
    lcd.home();
    lcd.setCursor(0,1);
    while(max_arm)
      delay(100);
      delay(100);
      delay(100);
      delay(100);
  lcd.setCursor(0,1);//2nd line lcd
  if (max_arm >= 10)
  if (max_arm < 10)
      lcd.write ("0");
      lcd.print(max_arm);
  lcd.print (":");
  if (Scount >= 10)
      lcd.print (Scount);
  if (Scount < 10)
      lcd.write ("0");
      lcd.print (Scount);
      max_arm--; // - 1 in minits
          //lcd.clear();
    if(max_arm==2)
    if(max_arm==1){
That rather confusing error is caused by the IDE's efforts to define function prototypes for you. This:
needs a type for the parameter - likely:
void timer1(int max_arm)
indeed..... i need to dust up the basics
