Error message I don't understand
Hello,
I have made what I thought was a working code but I keep getting an error message.
Heres the code
#include <LiquidCrystal.h>;
unsigned long startTime;
unsigned long stopTime;
unsigned long elapsedTime;
unsigned long Time;
boolean started = false;
boolean stopped = false;
int startPin = 9;
int stopPin = 8;
const int numRows = 2;
const int numCols = 16;
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
pinMode(stopPin, INPUT);
pinMode(startPin, INPUT);
 digitalRead;
void loop();
   if(digitalRead(startPin) == HIGH) // The sensor has been activated
   started = true;         // If this is ture start the timer
   startTime = micros(); // States when the senor has been crossed
  if(digitalRead(stopPin) == HIGH) // The sensor has been activated
   stopped = true;         // If this is ture start the timer
   stopTime = micros(); // States when the senor has been crossed
if(started && stopped)
   elaspedTime = stopTime - startTime; // How long did that take?
   Serial.print("Elapsed time, in microseconds: ");
   Serial.println(elapsed);
   started = false;  // Reset so the senors can be tripped again
   stopped = false;
Serial.print("Elapsed time, in seconds: ");
lcd.print("Elapsed time, in seconds: ");
The error message is
In function ‘viod setup()’ :
error: 'elaspedTime ’ was not declared in this scope
What does this mean and how do I fix it?
Cheers
Bye
Closing bracket the wrong way round.
void loop();
No semicolon here.
Thank you
But now I’m getting another error
void loop();
At the high lighted section I’m getting the error
error: expected unqualified-id before ‘{’ token
What should I do?
Remove the semicolon after void loop()
(and read a C programming tutotial :wink: )
RIght OK, that worked but now I getting the same message as before in relation to the eplasped time.
elaspedTime
You have written elapsed in three different ways, in this thread.
Check your typing :wink:
I should learn to read, well its working now thank you a great deal for the help. :slight_smile:
