Error message in my codes.
Hello everyone,
i am coming out with a simple program to control the LCD screen using a button. However i tried compiling it and it gave me this error . expected ';' before '(' token and expected primary-expression before ')' token. Can someone please help me to rectify the problem?
Thanks
#include <LiquidCrystal.h>
#define selector 8
LiquidCrystal lcd(12,11,5,4,3,2);
int Menu =-1;
int Status;
pinMode(6,INPUT_PULLUP);
pinMode(7, INPUT_PULLUP);
pinMode(8,INPUT_PULLUP);
pinMode(10,INPUT_PULLUP);
lcd.begin(16, 2);
// // put your main code here, to run repeatedly:
Status = digitalRead(selector);
if (Status ==0)
Menu++;
if (Menu ==3)
Menu=0;
switch(Menu)
case 0:
lcd.clear();
lcd.print("Autopilot");
break();
case 1:
lcd.clear();
lcd.print("Heading");
break();
case 2:
lcd.clear();
lcd.print("Altitude");
Hint: the error messages also reference line numbers. Go back and look at that, it will tell you where the problem occurred. It will be in that line or the one immediately before it.
Hello aarg,
Thanks for the reply but how would i know which line is the error found? kind of new to arduino. ino:34:12: error: expected ';' before '(' token and 34:13: error: expected primary-expression before ')' token
Thanks
break();
break is not a function.
Please use code tags when posting code
The codes worked already, Thanks so much for the help everyone (:
BoyBrand:
Hello aarg,
Thanks
Line 34.
