error message "JDate_frac not declared in this scope"
I'm trying to use this code on my adafruit esp32 feather but when I'm compiling it's not working. Could anybody help me. Thanks. Just to be clear it's not my code.
#include <ESP32_Servo.h>
#include <Wire.h>
This program calculates solar positions as a function of location, date, and time. The equations are from NOAA
This software, the ideas and concepts is Copyright (c) David Bird 2014 and beyond.
All rights to this software are reserved.
It is prohibited to redistribute or reproduce of any part or all of the software contents in any form other than the following:
 1. You may print or download to a local hard disk extracts for your personal and non-commercial use only.
 2. You may copy the content to individual third parties for their personal use, but only if you acknowledge the author David Bird as the source of the material.
 3. You may not, except with my express written permission, distribute or commercially exploit the content.
 4. You may not transmit it or store it in any other website or other form of electronic retrieval system for commercial purposes.
 5. You MUST include all of this copyright and permission notice ('as annotated') and this shall be included in all copies or substantial portions of the software and where the software use is visible to an end-user.
THE SOFTWARE IS PROVIDED "AS IS" FOR PRIVATE USE ONLY, IT IS NOT FOR COMMERCIAL USE IN WHOLE OR PART OR CONCEPT.
FOR PERSONAL USE IT IS SUPPLIED WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
IN NO EVENT SHALL THE AUTHOR OR COPYRIGHT HOLDER BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
#include <WiFi.h>    // Built-in
#include <time.h>    // Built-in
const char* ssid = "ASUS";
const char* password = "Hanna1988";
float Lon = 12.94 * DEG_TO_RAD,
      Lat = 55.4 * DEG_TO_RAD,
      elevation,
      azimuth;
#define elevation_servo 5
#define azimuth_servo   2
int sun_azimuth;
int sun_elevation;
String time_str, current_hour, current_minute, current_day, current_month, current_year;
Servo Azi_servo;
Servo Ele_servo;
  StartWiFi(ssid, password);
  StartTime();
  UpdateLocalTime();
  Azi_servo.attach(azimuth_servo);
  Ele_servo.attach(elevation_servo);
  test_azimuth();
  test_elevation(); // Stop at 145 which is vertical or 0 elevation
  // All time values must not be in DST
  UpdateLocalTime();
  Serial.println(Update_DateTime());
  Calculate_Sun_Position(current_hour.toInt(), current_minute.toInt(), 0, current_day.toInt(), current_month.toInt(), current_year.toInt()); // parameters are HH:MM:SS DD:MM:YY start from midnight and work out all 24 hour positions.
  Azi_servo.write(map(sun_azimuth, 90, 270, 180, 0));        // Align to azimuth
  if (sun_elevation < 0) sun_elevation = 0; // Point at horizon if less than horizon
  Ele_servo.write(145 - sun_elevation);  // map(value, fromLow, fromHigh, toLow, toHigh)
  delay(1 * 60 * 1000); // Wait 1-minute then check position again
void Calculate_Sun_Position(int hour, int minute, int second, int day, int month, int year) {
  float T, JD_frac, L0, M, e, C, L_true, f, R, GrHrAngle, Obl, RA, Decl, HrAngle;
  long JDate, JDx;
  int zone = 0;
  JDate      = JulianDate(year, month, day);
  JDate_frac = (hour + minute / 60. + second / 3600.0) / 24.0 - 0.5;
  T          = JDate - 2451545; T = (T + JDate_frac) / 36525.0;
  L0         = DEG_TO_RAD * fmod(280.46645 + 36000.76983 * T, 360);
  M          = DEG_TO_RAD * fmod(357.5291 + 35999.0503 * T, 360);
  e          = 0.016708617 - 0.000042037 * T;
  C          = DEG_TO_RAD * ((1.9146 - 0.004847 * T) * sin(M) + (0.019993 - 0.000101 * T) * sin(2 * M) + 0.00029 * sin(3 * M));
  f          = M + C;
  Obl        = DEG_TO_RAD * (23 + 26 / 60.0 + 21.448 / 3600. - 46.815 / 3600 * T);
  JDx        = JDate - 2451545;
  GrHrAngle  = 280.46061837 + (360 * JDx) % 360 + 0.98564736629 * JDx + 360.98564736629 * JD_frac;
  GrHrAngle  = fmod(GrHrAngle, 360.0);
  L_true     = fmod(C + L0, 2 * PI);
  R          = 1.000001018 * (1 - e * e) / (1 + e * cos(f));
  RA         = atan2(sin(L_true) * cos(Obl), cos(L_true));
  Decl       = asin(sin(Obl) * sin(L_true));
  HrAngle    = DEG_TO_RAD * GrHrAngle + Lon - RA;
  elevation  = asin(sin(Lat) * sin(Decl) + cos(Lat) * (cos(Decl) * cos(HrAngle)));
  azimuth    = PI + atan2(sin(HrAngle), cos(HrAngle) * sin(Lat) - tan(Decl) * cos(Lat)); // Azimuth measured east from north, so 0 degrees is North
  sun_azimuth   = azimuth   / DEG_TO_RAD;
  sun_elevation = elevation / DEG_TO_RAD;
  Serial.println("Longitude and latitude " + String(Lon / DEG_TO_RAD, 3) + " " + String(Lat / DEG_TO_RAD, 3));
  Serial.println("Year\tMonth\tDay\tHour\tMinute\tSecond\tElevation\tAzimuth");
  Serial.print(String(year) + "\t" + String(month) + "\t" + String(day) + "\t" + String(hour - zone) + "\t" + String(minute) + "\t" + String(second) + "\t");
  Serial.println(String(elevation / DEG_TO_RAD, 0) + "\t\t" + String(azimuth / DEG_TO_RAD, 0));
long JulianDate(int year, int month, int day) {
  long JDate;
  int A, B;
  if (month <= 2) {year--; month += 12;}
  A = year / 100; B = 2 - A + A / 4;
  JDate = (long)(365.25 * (year + 4716)) + (int)(30.6001 * (month + 1)) + day + B - 1524;
  return JDate;
////////////// WiFi, Time and Date Functions /////////////////
int StartWiFi(const char* ssid, const char* password) {
  int connAttempts = 0;
  Serial.print(F("\r\nConnecting to: ")); Serial.println(String(ssid));
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED ) {
    delay(500); Serial.print(".");
    if (connAttempts > 20) {
      Serial.println("\nFailed to connect to a Wi-Fi network");
      return false;
    connAttempts++;
  Serial.print(F("WiFi connected at: "));
  return true;
void StartTime() {
  configTime(0, 0, "0.uk.pool.ntp.org", "time.nist.gov");
  setenv("TZ", "GMT0BST,M3.5.0/01,M10.5.0/02", 1); // Change for your location
  UpdateLocalTime();
void UpdateLocalTime() {
  struct tm timeinfo;
  while (!getLocalTime(&timeinfo)) {
    Serial.println("Failed to obtain time");
  //See http://www.cplusplus.com/reference/ctime/strftime/
  Serial.println(&timeinfo, "%a %b %d %Y   %H:%M:%S"); // Displays: Saturday, June 24 2017 14:05:49
  char output[50];
  strftime(output, 50, "%a %d-%b-%y  (%H:%M:%S)", &timeinfo);
  time_str = output;
String GetTime() {
  struct tm timeinfo;
    Serial.println("Failed to obtain time - trying again");
  //Serial.println(&timeinfo, "%a %b %d %Y %H:%M:%S"); // Displays: Saturday, June 24 2017 14:05:49
  char output[50];
  strftime(output, 50, "%d/%m/%y %H:%M:%S", &timeinfo); //Use %m/%d/%y for USA format
  time_str = output;
  Serial.println(time_str);
  return time_str; // returns date-time formatted like this "11/12/17 22:01:00"
String Update_DateTime() {
  struct tm timeinfo;
  char output[50];
  strftime(output, 50, "%H", &timeinfo);
  current_hour   = output;
  strftime(output, 50, "%M", &timeinfo);
  current_minute = output;
  strftime(output, 50, "%d", &timeinfo);
  current_day    = output;
  strftime(output, 50, "%m", &timeinfo);
  current_month  = output;
  strftime(output, 50, "%Y", &timeinfo);
  current_year   = output;
void test_azimuth() {
  Azi_servo.write(90);  // Centre position
  Azi_servo.write(60);  // Centre position
  Azi_servo.write(120); // Centre position
void test_elevation() {
  for (int a = 5; a < 145; a = a + 2) {
    Ele_servo.write(a);  // Centre position
    delay(30);
  Ele_servo.write(145);  // Centre position
solar_tracker_2d.ino (8.19 KB)
What do you mean with "it's not working"
  • Can it be compiled with no error?
  • Can you upload it?
If there is an compiling error, please post it.
I suspect that JDate_frac is actually supposed to be JD_frac.
