Error message: ld returned 1 exit status (using Arduino and ESP8266)
Hello :).
I have tried compiling my code, but the following error:
C:\Users\nanna\AppData\Local\Temp\buildb39ad8e752d487d12abae3a785f78780.tmp/arduino.ar(time.c.o): In function `time':
C:\Users\nanna\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\cores\esp8266/time.c:93: multiple definition of `time'
sketch\ESP_test.ino.cpp.o:C:\Users\nanna\Documents\Arduino\libraries\PJON-master/PJON.h:98: first defined here
c:/users/nanna/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9-2/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: Warning: size of symbol `time' changed from 4 in sketch\ESP_test.ino.cpp.o to 29 in C:\Users\nanna\AppData\Local\Temp\buildb39ad8e752d487d12abae3a785f78780.tmp/arduino.ar(time.c.o)
c:/users/nanna/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9-2/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: Warning: type of symbol `time' changed from 1 to 2 in C:\Users\nanna\AppData\Local\Temp\buildb39ad8e752d487d12abae3a785f78780.tmp/arduino.ar(time.c.o)
collect2.exe: error: ld returned 1 exit status
I know that it mens I have errrors, but I can't seem to understand what I'm supposed to change. Does anybody understand what Arduino is asking for?
I hope you can help me.
Cheers
The compiler seems to be complaining that there are multiple definitions of time, but unless you post your program I doubt if you will get any help.
