Error Message "lvalue required as left operand of assignment"
I am super new to the whole coding scene and wanted some help. I have looked up a lot about this error message but I couldn't get anything to work while troubleshooting.
my code is the following:
define trigePin 9
define echooPin 10
void setup() { // put your setup code here, to run once: Serial.begin(9600); pinMode(trigePin = OUTPUT); pinMode(echooPin = INPUT);
void loop() { // put your main code here, to run repeatedly: digitalWrite (trigePin, LOW); delayMicroseconds(5);
digitalWrite (trigePin, HIGH); delayMicroseconds(10); digitalWrite (trigePin, LOW);
duration = pulseIn (echooPin, HIGH); distance = duation/58.2;
Serial.print ("DISTANCE: "); Serial.print (distance); }
It is giving me this error on this: #define echooPin 10
Any suggestions on how to get better and fix this?? Thank you :)
Look up the syntax for the pinMode function in the language reference.
Read the how to use this forum-please read stickies to see how to properly post code.
The duration and distance variables are not declared anywhere and duation != duration Maybe something like this?
unsigned long duration = pulseIn (echooPin, HIGH);
float distance = duration/58.2;
Thank you a ton! I hadn't ever used that reference, but that helps a lot!
