Hi, I'm new to Arduino, I've connected an Arduino Uno to my PC (win 7) and when I try to put a code in the sketch page, I get this error message:
Not used: C:\Program Files (x86)\Arduino\libraries\Adafruit-WS2801-Library-1.1.0
exec: "{runtime.tools.ctags.path}/ctags": file does not exist
Error compiling for board Arduino Uno.
Could you help me?
This looks like a library installed in the wrong place.
Could you go into Preferences and turn on verbose messages during compilation? Then try to compile the program again and report back with all of the text that shows up under the sketch window. You can copy and paste from the message window.
Here it is. I don't know if I have to put the library in programfiles(86) or in users
Arduino: 1.8.16 (Windows 7), Board: "Arduino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Utilisateur\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0000_0000 -ide-version=10816 -build-path C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_381420 -warnings=none -build-cache C:\Users\UTILIS~1\AppData\Local\Temp\arduino_cache_254799 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Utilisateur\Documents\Arduino\libraries\Adafruit-WS2801-Library-1.1.0\sketch_nov21a\sketch_nov21a\sketch_nov21a.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Utilisateur\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0000_0000 -ide-version=10816 -build-path C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_381420 -warnings=none -build-cache C:\Users\UTILIS~1\AppData\Local\Temp\arduino_cache_254799 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Utilisateur\Documents\Arduino\libraries\Adafruit-WS2801-Library-1.1.0\sketch_nov21a\sketch_nov21a\sketch_nov21a.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_381420\sketch\sketch_nov21a.ino.cpp" -o nul
Alternatives for Adafruit_WS2801.h: [Adafruit-WS2801-Library-1.1.0@1.1.0]
ResolveLibrary(Adafruit_WS2801.h)
-> candidates: [Adafruit-WS2801-Library-1.1.0@1.1.0]
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Users\Utilisateur\Documents\Arduino\libraries\Adafruit-WS2801-Library-1.1.0" "C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_381420\sketch\sketch_nov21a.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Users\Utilisateur\Documents\Arduino\libraries\Adafruit-WS2801-Library-1.1.0" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_381420\sketch\sketch_nov21a.ino.cpp" -o nul
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Users\Utilisateur\Documents\Arduino\libraries\Adafruit-WS2801-Library-1.1.0" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\Utilisateur\Documents\Arduino\libraries\Adafruit-WS2801-Library-1.1.0\Adafruit_WS2801.cpp" -o nul
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Users\Utilisateur\Documents\Arduino\libraries\Adafruit-WS2801-Library-1.1.0" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src\SPI.cpp" -o nul
Generating function prototypes...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Users\Utilisateur\Documents\Arduino\libraries\Adafruit-WS2801-Library-1.1.0" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_381420\sketch\sketch_nov21a.ino.cpp" -o "C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_381420\preproc\ctags_target_for_gcc_minus_e.cpp"
{runtime.tools.ctags.path}/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_381420\preproc\ctags_target_for_gcc_minus_e.cpp"
Using library Adafruit-WS2801-Library-1.1.0 at version 1.1.0 in folder: C:\Users\Utilisateur\Documents\Arduino\libraries\Adafruit-WS2801-Library-1.1.0
Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
I don't have any SPI folder in Program86/Arduino/Library/
Are you able to compile other sketches without error?
No, that's the first one i'm doing
He means sketches written by other people... like the example sketches, Blink.ino for example
Hi @jjcanot. Does this file exist on your computer?
C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11\ctags.exe
Yes I tried Blink, same problem
I don't have any tools-builder folder. And it's not in tools
Sorry, I found the SPI folder..
There's your problem!
Try reinstalling the Arduino IDE.
Ok I will try that tonight.
Thanks
Ok, I re install Arduino on my computer, and it works fine now. It looks my anti virus was deleting some files. So I turn it off.
I have other errors, I will try to fix that myself before asking for help.
Thank you very much to all of you for your help and your quick answer.
I'm glad to hear that you found the solution for the ctags error. That is progress even if there are still other problems to resolve!
