error message on verifyng a code
Hello ! I have a error mesage when i try to verify this code:
#include <LiquidCrystal.h>
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);    //set LCD output pins
//define stepper driver pins
const int stp = 11;    //can't use pin 10 with the SS LCD as it's the backlight control.
//if it goes low, backlight turns off!
const int dir = 12;
//define trigger pin
const int trig = 13;
//BUTTONS
//define button values
const int btnUp = 0;
const int btnDn = 1;
const int btnL = 2;
const int btnR = 3;
const int btnSel = 4;
const int btnNone = 5;
//define button-reading variables
int btnVal = 5;
int adcIn = 0;
  lcd.begin(16, 2);               // initialise LCD lib full-screen
  lcd.setCursor(0,0);             // set cursor position
  pinMode(stp, OUTPUT);           //initialise stepper pins
  pinMode(dir, OUTPUT);
  pinMode(trig, OUTPUT);           //initialise trigger pin
  digitalWrite(trig, LOW);         //ensure trigger is turned off
  lcd.print("Welcome to");  //welcome screen
  lcd.setCursor(0,1);
  lcd.print("SliderCam v0.2!");
  lcd.clear();
  lcd.print(menuItemsTop[0]);
  delay(100);
  lcd.setCursor(0,1);
  for (int i = 0; i < 4; i++) {
    lcd.setCursor(i, 1);
    lcd.print(currentDistance[i]);
  lcd.setCursor(4,1);
  lcd.print("mm(max 1300)");
  do {
    btnVal = readLcdButtons();      //continually read the buttons...
  while (btnVal==5);              //...until something is pressed
//declare button poll function
int readLcdButtons() {
  delay(90); //debounce delay, tuned experimentally. delay is fine as program shouldn't be doing anything else
  //at this point anyway
  adcIn = analogRead(0); //read value from pin A0
  /*threshold values confirmed by experimentation with button calibration sketch returning the following ADC read values:
   right: 0
   up: 143
   down: 328
   left: 504
   select: 741
  if (adcIn > 1000) return btnNone;
  if (adcIn < 50)   return btnR;
  if (adcIn < 250)  return btnUp;
  if (adcIn < 450)  return btnDn;
  if (adcIn < 650)  return btnL;
  if (adcIn < 850)  return btnSel;
  return btnNone; //if it can't detect anything, return no button pressed
//PRINT NEW SCREEN VALUES
  btnVal=btnNone;
  lcd.clear();
lcd.setCursor(0, 0);
  lcd.print(menuItemsTop[currentMenuItem]);    //print top level menu item
lcd.setCursor(0,1);
 switch (currentMenuItem) {
 case 0:
 case 1:
     for (int i = 0; i < 6; i++) {
       lcd.print(currentDuration[i]);
 case 2:
       lcd.print(currentSteps[i]);
 case 3:
     if (travelDir == 0) lcd.print("From Motor");
     else lcd.print("To Motor");
 case 4:
     lcd.print("Stop!");
 }  //end switch
if (currentMenuItem==0){
    lcd.setCursor(4,1);
    lcd.print("mm(max 1300)");    //insert max carriage travel on slider used
  if (currentMenuItem==1){
    lcd.setCursor(6,1);
    lcd.print("s(3600/hr)");
  if (currentMenuLevel == 1) {
    lcd.setCursor(currentCursorPos, 1);
    lcd.blink();
  else lcd.noBlink();
//MENU GUI
//define top-level menu item strings for numerical navigation
char* menuItemsTop[] = {
  "  01 Distance >", "< 02 Duration >", "< 03 Steps > ", "< 04 Direction >", "< 05 Go!"};
int currentMenuLevel = 0;      //top menu or submenu
int currentMenuItem = 0;       //x-axis position of menu selection
int currentCursorPos = 0;      //current lcd cursor position
int currentDistance[4] = {
  0, 0, 0, 0};
int currentDuration[6] = {
  0, 0, 0, 0, 0, 0};
int currentSteps[4] = {
  0, 0, 0, 1};
if (currentMenuLevel==0) {
    switch (btnVal){
    case  btnL:
        if (currentMenuItem == 0) break;      //can't go left from here
        else currentMenuItem--;
    case  btnR:
        if (currentMenuItem == 4) break;      //can't go right from here
        else  currentMenuItem++;
    case  btnSel:
        currentMenuLevel++;
        if (currentCursorPos > 3 && (currentMenuItem == 0 || currentMenuItem == 2)) currentCursorPos = 3; //don't go off the end of the numbers for the 4-digit numbers
        if (currentCursorPos > 0 && (currentMenuItem > 2)) currentCursorPos = 0; // set blinking cursor to left for text-based options
        if (currentMenuItem == 4) {
          motion = 1;
          motionControl();
    } //end of switch
  } //end of level 0
else {    // i.e. "else if currentMenuLevel = 1"
    if (currentMenuItem == 0) { //01 DISTANCE
      switch (btnVal) {
      case btnUp:
          currentChar = currentDistance[currentCursorPos];
          adjustDigit(currentChar, 1);
          currentDistance[currentCursorPos] = currentChar;
      case btnDn:
          adjustDigit(currentChar, 0);
      case btnL:
          if (currentCursorPos == 0) break;      //can't go left from here
          else currentCursorPos--;
      case btnR:
          if (currentCursorPos == 3) break;      //can't go left from here
          else currentCursorPos++;
      case btnSel:
          parseArrayDistance();
          currentMenuLevel--;
      }    //end switch
    }      //end DISTANCE
int adjustDigit(int x, int dir){      //digit adjust function
  if (dir == 0 && x > 0) x--;         //subtract from digit on btnDn
  if (dir == 1 && x < 9) x++;         // add to digit on btnUp
  lcd.print(x);
  currentChar = x;
  return currentChar;                 //return new digit
  lcd.print(x);
  currentChar = x;
int motionControl() {
  totalMotorSteps = currentDistanceInt * 5; //calculate total steps (0.2mm = 20-tooth gear on 2mm pitch belt; 40mm per rev, 200 steps per rev, ergo 1/5th mm per step)
  pulseDelay = (1000L * (currentDurationInt - (currentStepsInt * shutterDuration))) / totalMotorSteps; //how long to pause in ms between STP pulses to the motor driver
  intervalDistance = totalMotorSteps / currentStepsInt;
//once per overall run
  if (travelDir == 0) digitalWrite(dir, LOW);
  else if (travelDir == 1) digitalWrite(dir, HIGH);
  //Serial.begin(9600);
  //Serial.println(pulseDelay);
  //step loop
  do {
    digitalWrite(stp, HIGH); //fire motor driver step
    delay(pulseDelay);
    digitalWrite(stp, LOW); //reset driver
    //btnVal = readLcdButtons(); //check there's no stoppage - this takes too long and significantly slows motor; use reset for stop!
    currentStep++;
    //at end of each step
    if (currentStep % intervalDistance == 0) {    //if current number of motor steps is divisible by the number of motor steps in a camera step, fire the camera
      digitalWrite(trig, HIGH); //trigger camera shutter
      delay(80);
      digitalWrite(trig, LOW);    //reset trigger pin
      delay((shutterDuration * 1000)-80); //delay needs changing to timer so stop button can be polled
  while (currentStep < totalMotorSteps);
} //end motion control
the message is : ,menuItemsTop, was not declared in this scope
I am using this code for a project Timelapse Slider from this link :
I am using a Arduino Uno + LCD Keypad Shield + Pololu A4988 [Black Edition] Stepper Driver.
Post all the code between code tags (see stickie for posting on this forum).
G.
Can you see the end of the "loop()" function.
I can't - you appear to have other function definitions embedded in it.
OldSteve:
You've left out virtually all of the menu declarations including 'menuItemsTop', along with 'currentDistance', and probably much more.
Aha, I see - you've just quickly copied and pasted those declarations, along with function definitions, inside the 'loop()' function.
Do you have exactly the same hardware as in the example you're following?
If so, did you test the provided example before attempting to modify it?
Finally, and most importantly, do you have much experience in writing C++ code and setting up hardware?
I already know the answer to this now. I think you've bitten off more than you can chew. You might have a chance of getting the original code working if you have exactly the same hardware, but otherwise you're going to need to do a fair amount of studying and practice with simpler examples before you tackle a complex project like modifying this to suit your needs.
I see that AWOL has just also pointed out part of this. To be honest, it's a mess. :frowning:
(Sorry to be so blunt, but it's true.)
Yes , you have right , i am starter with this things and i try to build a slider , i have the same hardware as the example , i.m not trying to modify , but in the example the code is posted steps and explained , I will do more practice with exemples and thank you very much for your advices :smiling_face:
cjohnny67:
You modified your original post and deleted your later one such that my comments didn't relate to anything that remains, so I deleted them.
For future reference, when you receive information later in a thread, don't go back and edit your original post to reflect that advice. It makes those that have already answered look foolish, and makes their replies totally irrelevant to the thread, for others that come along and read it.
If you have the exact same hardware and don't wish to modify the code, why did you not just test the example as presented in the tutorial you were following? It compiled fine.
I'll leave you to it at this point.
OldSteve:
Sorry for deleting the thread , I will verify the connections because the hardware is the same and in the exemple the wiring scheme is not quite clear and now i thing that the main reason is the wiring .
