error message please help me [solved]
I made a code and I thought it would work but i got the error
Zonnepanelen_Programma:79: error: expected unqualified-id before ‘if’
The code i used is
#include <Servo.h>
int light_sensitivity = 500;    //This is the approx value of light surrounding your LDR
int LDR = 0;     //analog pin to which LDR is connected, here we set it to 0 so it means A0
int LDRValue = 0;      //that’s a variable to store LDR values
 Servo motorA;
 int val;
 motorA.attach(12);
    LDRValue = analogRead(LDR);      //reads the ldr’s value through LDR
    Serial.println(LDRValue);       //prints the LDR values to serial monitor
    delay(50);        //This is the speed by which LDR sends value to arduino
    if (LDRValue > light_sensitivity)
        {motorA.detach();
        }}else
       motorA.attach(12);
        motorA.write(10);
        {motorA.detach();
        }}else
        motorA.attach(12);
        motorA.write(20);
      {{motorA.detach();
      }}else
        motorA.attach(12);
        motorA.write(30);
      {{motorA.detach();
  }}else
         motorA.attach(12);
        motorA.write(40);
      {{motorA.detach();
  }}else
  motorA.attach(12);
        motorA.write(50);
      {{motorA.detach();
  }else
  motorA.attach(12);
        motorA.write(60);
      {{motorA.detach();
  }else
  motorA.attach(12);
        motorA.write(70);
      {{motorA.detach();
  }else
   motorA.attach(12);
        motorA.write(80);
      {{motorA.detach();
  }else
  motorA.attach(12);
        motorA.write(90);
       {motorA.detach();
  }else
  motorA.attach(12);
        motorA.write(100);
         {motorA.detach();
  }else
  motorA.attach(12);
        motorA.write(110);
        {motorA.detach();
  }else
  motorA.attach(12);
        motorA.write(120);
      {{motorA.detach()
  }else
        ;motorA.attach(12);
        motorA.write(130);
      {{motorA.detach()
  }else
        ;motorA.attach(12);
        motorA.write(140);
      {{motorA.detach();
  }else
         motorA.attach(12);
        motorA.write(150);
      {{motorA.detach();
  }else
         motorA.attach(12);
        motorA.write(160);
      {{motorA.detach();
  }else
         motorA.attach(12);
        motorA.write(170);
      {{motorA.detach();
        motorA.attach(12);
        motorA.write(180);
Can somebody help me?
That's some eccentric code formatting you've got there.
AWOL: That's some eccentric code formatting you've got there.
I was trying to make a shadow seeking servo
You can't have executable code that isn't in a function.
AWOL: You can't have executable code that isn't in a function.
but everyting worked until i swapped every motorA.detach(); with motorA.attach(12); motorA.write(60); delay(1000);
So, go back to that code. If it worked, why did you change it?
AWOL: So, go back to that code. If it worked, why did you change it?
it didn't work as i wanted it to work. it didn't stop when there was a shadow.
What is going on with all this attaching and detaching motors?
aarg: What is going on with all this attaching and detaching motors?
making it stop moving when the ldr sees a shadow
It looks to me like the block with the "write(60)" is not inside the loop() function. That isn't allowed.
Sort out your {} braces, and you should see the problem.
AWOL: It looks to me like the block with the "write(60)" is not inside the loop() function. That isn't allowed.
That was indeed the problem i got the program to work now
