error message please help
this is one of my first programs and my error message says "expected ')' before ';' token" in the void loop() function please help
(Please use code tags. Thanks! Moderator.)
// set pin numbers:
const int buttonPin[] = {5,6};     // the number of the pushbutton pins
const int relayPin =  13;// the number of the relay pin
// variables will change:
int buttonState = 0;         // variable for reading the pushbutton status
 // initialize the LED pin as an output:
 pinMode(relayPin, OUTPUT);
 // initialize the pushbutton pin as an input:
 for(int x=0; x<2; x++)
   pinMode(buttonPin[x], INPUT);
void loop(){
 // read the state of the pushbutton value:
   (buttonState = digitalRead(buttonPin[x]);
   // check if the pushbutton is pressed.
   // if it is, the buttonState is HIGH:
   if (buttonState == HIGH && buttonPin[x] == 2) {
     // turn LED on:
     digitalWrite(relayPin, LOW);
   if (buttonState == LOW && buttonPin[x] == 2) {
     // turn LED on:
     digitalWrite(relayPin, HIGH);
   if (buttonState == HIGH && buttonPin[x] == 3) {
     // turn LED off:
sorry here is the program
const int buttonPin[] = {2,3};     // the number of the pushbutton pins
void loop(){
      // turn LED on:
      // turn LED on:
      // turn LED off:
This line has an extra ( at the start (or, is missing one at the end).
