Arduino: 1.8.9 (Mac OS X), Board: "Arduino/Genuino Uno"
Sketch uses 2296 bytes (7%) of program storage space. Maximum is 32256 bytes.
Global variables use 212 bytes (10%) of dynamic memory, leaving 1836 bytes for local variables. Maximum is 2048 bytes.
/private/var/folders/57/wk5m98ln30n9q05jkfw9bcj4mzk8pj/T/AppTranslocation/277A3FC8-753B-4572-A46D-85CB3B9735E2/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/private/var/folders/57/wk5m98ln30n9q05jkfw9bcj4mzk8pj/T/AppTranslocation/277A3FC8-753B-4572-A46D-85CB3B9735E2/d/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbmodem1461 -b115200 -D -Uflash:w:/var/folders/57/wk5m98ln30n9q05jkfw9bcj4mzk8pj/T/arduino_build_704533/auto_go.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/private/var/folders/57/wk5m98ln30n9q05jkfw9bcj4mzk8pj/T/AppTranslocation/277A3FC8-753B-4572-A46D-85CB3B9735E2/d/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/gerlof1/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem1461
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
