Error message stating "expected primary-expression before 'long'"
  Serial.print(long read(), 1);
  Serial.println(" g");
  delay(200);
  int weight1 = scale.getGram();
  if weight1 != scale.getGram() {
    tone(6,440,5000);
So I am trying to build a scale with the HX711 shield, but scale.getGram does not seem to be an existing element. So now I am trying to use long read, but it keeps saying "expected primary-expression before 'long'"?
What on earth are you attempting to do with that line?
That is not valid c syntax - I can't tell if you mean a cast (which requires the datatype in parens) or what.
What is read()? You haven't included that code...
That code is not right, either. if statements have parentheses around the condition.
And, you should get in the habit, NOW, of putting each { and each } on a line BY ITSELF.
