im having problems reading the analogue pin and sending the value through Bluetooth to my LCD.
can someone tell me whats wrong please, thank you very much.
This is the code for the master device
int val;
#define button 3
Serial.begin(38400);
pinMode(button , INPUT);
val = digitalRead(button);
if (val == HIGH)
int sensor = analogRead(A0);
float voltage0 = sensor * (5.0/1023.0);
Serial.write(voltage0);
delay(50);
and then i get this error message
Arduino: 1.8.4 (Windows 7), Board: "Arduino/Genuino Uno"
C:\Sams Folder\Code_for_master_device__full_\Code_for_master_device__full_.ino: In function 'void loop()':
Code_for_master_device__full_:16: error: call of overloaded 'write(float&)' is ambiguous
C:\Sams Folder\Code_for_master_device__full_\Code_for_master_device__full_.ino:16:26: note: candidates are:
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:232:0,
from sketch\Code_for_master_device__full_.ino.cpp:1:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:129:20: note: virtual size_t HardwareSerial::write(uint8_t)
virtual size_t write(uint8_t);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:130:19: note: size_t HardwareSerial::write(long unsigned int)
inline size_t write(unsigned long n) { return write((uint8_t)n); }
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:131:19: note: size_t HardwareSerial::write(long int)
inline size_t write(long n) { return write((uint8_t)n); }
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:132:19: note: size_t HardwareSerial::write(unsigned int)
inline size_t write(unsigned int n) { return write((uint8_t)n); }
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:133:19: note: size_t HardwareSerial::write(int)
inline size_t write(int n) { return write((uint8_t)n); }
exit status 1
option enabled in File -> Preferences.
This is the code for the slave device
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int val;
int voltage0;
int Intvol;
lcd.begin(16, 2);
if(Serial.available() > 0)
val = Serial.read();
if (val==voltage0)
lcd.setCursor (0,0);
lcd.print(val);
delay(200);
