Error Message. Trying to use the NewPing and IRremote libraries
So I'm trying to use the two libraries for a car project, so basically, I want that a car stop whenever the car reaches a minimum distance but every time I try to compile it I keep getting this error:
Arduino: 1.8.5 (Linux), Board: "Arduino/Genuino Uno"
libraries/NewPing/NewPing.cpp.o (symbol from plugin): In function intFunc2': (.text+0x0): multiple definition of __vector_7'
libraries/IRremote/IRremote.cpp.o (symbol from plugin):(.text+0x0): first defined here
collect2: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
For extra information, I will attach the program.
IR_Car_with_Distance.ino (2.81 KB)
Which you clearly have done no research for.
Both libraries are trying to use the same timer. The latest version of the IRlibrary, at least, allows you to change which timer it uses. You'll need to research the available timers, and the advantages and drawbacks of using each timer.
Decide which drawbacks you can live with, and change one library to use a different timer.
